Rim diameter? - Ford Powerstroke Diesel Forum
Old 08-07-2008, 03:09 PM
Rim diameter?
im gettin 38x15.50x16 and im looking to buy rims can i run 16x8's on those tires? also what the bolt pattern and back spacing i should get? thanks alot
what if i get 37x13.50x16? what size rim?
Old 08-07-2008, 03:16 PM
u might be abl to get away with an 8" wide rim with the 13.50's but if you get the 15.50's you would need a minimum of a 10" wide rim..
Old 08-07-2008, 03:18 PM
I dont think you can, Im pretty sure you need at least a 10" wide rim if not 12" Im not sure about the offset but the bolt pattern is 8 x 170mm
even with a 13.5 tire I think you need a 10" wide rim. hopefully someone else will chime in that knows for sure.
