BIODIESEL - Ford Powerstroke Diesel Forum
Old 08-06-2008, 08:33 AM
BIODIESEL
Could i run bio in my 97 powerstroke?
Old 08-06-2008, 08:10 PM
No in exactly 3.25 miles the motor will seize.
:r ofl: My truck has been a vegitarian since I bought it, and it works great. Read through the Bio/Alternative section there are probably 200+ people on this forum that are using Bio from IDI fords all the way up to 6.0s.
Old 08-06-2008, 09:30 PM
Sure! Some places will allow you decide what the blend is. I've run B99. No problems. Drove from Bend, OR to Sacramento, CA on it. Ran smooth as dino diesel. Fuel mileage calculated out to about 1/2 mile a gallon better.
Old 08-07-2008, 04:17 AM
Thank you...I wasnt sure because i heard some people say that it could eat through your fuel lines and that you would have to change fuel filters more often???
Old 08-07-2008, 05:12 PM
i to run bio, a friends sells kits
Old 08-07-2008, 08:06 PM
typically after the first 2nd or 3rd tank of it you have to change your fuel filter becuase Bio is like a big colon cleanser and dislodges all the years of built up algae. But after that you are good to go. The only other time it will plug a filter is when you run it too cold in the winter and it is gelled, but in that case the truck probably wouldnt start in the first place.
in point its as safe as diesel to run, in mild climates. If you can get it cheaper or make it cheaper than pulling up the pump you are good to go. If its costs more or about the same you are just wasting your time.
