How to raise MPG on high milage 6L - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-09-2013, 11:16 AM Thread Starter
Hello,
I have a 2006 F350 with a 6L power stroke. It has reached 350,000 miles and I am only getting around 400 miles per tank vs 500 to 600 that I used to get. What can I do to raise the mileage? Is there any maintenance that I need to perform (such as spark plugs) that would help?
Thanks,
jimmy
jimmyfromwv is offline
post #2 of 3 Old 11-09-2013, 11:27 AM
Term3's Avatar
Quoted: 2 Post(s)
Originally Posted by jimmyfromwv View Post
Hello,
Thanks,
jimmy
Spark plugs???? OH BOY, first off read up on your diesel.
Here's some good reading materials.
Powerstroke Info
If your injectors are high mileage there's not a whole lot you can do. Could try an economy tune to see if that helps.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 3 Old 11-09-2013, 11:27 AM
the black lemon's Avatar
you do not have to worry about sparkplugs....diesel uses compression and heat ...i would run a couple flushes for the oil to clean out and possible sludge and the same with the transmisson and the diff over time your exgusht pipe will build carbine and cloge up and clean injectors change airfilter piping to turbo and everything from turbo to intake manifold is gonna have carbine that builds and cloges....pretty much if you can think of it...its dirty and a good cleaning will help bring miles back if not add some
the black lemon is offline
