wow!!! it is not blown!!!!!!!!!! need injector advice
well, fortunately i havent parted out anything to keep this old bad boy from running.
found out i am essentially hydrolocked. have diesel in oil pulled drivers valve cover. pulled glow plugs 2nd from front had 3/8" of tip burned off cranked engine without harness wired so no fire and 2nd cylinder blew out massive amounts of diesel. pulled injector and half of the whole length of one side of the nozzle is blown off. blew the rest out of that cylinder. can i get away with just replacing the nozzle. don't have the money to buy a new one for 250 let alone another set. seen a tool for doing this on ebay for 75 shipped. where do i get the nozzles or a single remanned injector for less. thank you all!! |
if you replace one your better off doing all 8 man, if not it'll bit you in the butt
excuse my ignorance. i'm mechanical, but learning as i go. how would it bite me in the butt?
DIY-Injectors.com
There are others. There are kits and are not hard to rebuild. These injectors should be rebuilt or replaced at 125,000 miles for best results. |
found 1 for 135 online. looking for a better deal if you know of a site. thanks.
want to give me the HPOP
There was a guy on here earlier that had a whole set for $400. I know its not what ya want but its cheap!
