Code P1280 ICP circuit out of range / low - Ford Powerstroke Diesel Forum
Old 07-24-2008, 12:56 PM
been tracking down and fixing codes am down to this one last code P1280 ICP circuit out of range/low. Any thoughts on how to correct this problem? Any help would be greatly appreciated. 1996 f350 psd auto.
Thanks
Old 07-24-2008, 01:08 PM
International Threat
ICP sensor related. Is your truck chipped or have you installed a 10k mod? Do you have an SES light?
Old 07-24-2008, 01:25 PM
i recently purchased a superchips 1705 for diagnostic purposes and tried the different tuning options is is now back to stock.what is a 10K mod and SES light?
thanks
Old 07-24-2008, 01:34 PM
i did have a cheapo dfuser chip installed but removed that some time ago.
Old 07-24-2008, 01:37 PM
mine does it too if i get into it alot how can u stop in
Old 07-24-2008, 01:44 PM
oh yeah forgot to mention the auto. trans. wont stay in one gear (shifts up and down when it should be staying in the higher gear and just noticed that the cruise control is not working.) also has a hard shift when the check engine light is on.
thanks
Old 08-09-2008, 12:07 AM
Send a message via AIM to stroken'n'smoken
same here
Just got home from OCMD. wednesday night i noticed my check engine light was on when i first started my truck.... shut off pretty soon after that. The following night, thurs., i noticed the same thing and while driving i noticed the trans was shifting harrrdddd. i stopped at wawa and shut it off and checked trans fluid and oil. Both a little low so i topped them off. Started truck and same deal, light comes on with hard shifts. after i got back on the main street and drove about a block i noticed the light was off and it shifted fine. Friday morning i go to leave and its doing the same with hard shifts. I fill up and get back on my way. After about a half hour of driving the light was still on and the truck was running like total crap. So after it shut off while at idle a few times i came to an auto zone and changed the fuel filter and checked the oil just in case. Started her up, ran pretty good, only had one sputter after that from the MD/DE line all the way up to philly. but the light was still on and it was still shifting hard. I get back and my buddy scanned it w/ a snap on scanner an it threw the P1280 "Injector Control Pressure out of range-Low" code. Im freaking out right now, i gotta head up to school a week from tomorrow and i gotta get this thing fixed. Any ideas.
Old 08-11-2008, 02:07 PM
i have put my truck on the "back burner" and concentrating on my daily driver. am a little reluctant to take the truck back to the shop as in the the past they have charged big for diagnostics and no given me
no clear solution to the problem. will be continuing to track down the problem as time and money becomes available. will kep you posted.
Old 08-30-2008, 02:14 PM
a little late i know, but i figured out that my hard shift/p1280 code was due to a bad icp regulator and oil pressure sensor. the snap on tool said the cps was intermittent too but im gonna wait on that til i get done moving back to school.
