7.3 vs. 6.0 vs. 6.4 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-22-2013, 08:00 PM Thread Starter
7.3 vs. 6.0 vs. 6.4
I will be looking at getting my first diesel come spring or summer. I know the 7.3 is a tank and the most reliable but also the lowest on power. And that the 6.0 and 6.4 are good but both have their own problems. I plan on owning the truck for a long time so I want something reliable and will try to get something with less than 100k miles. I know this will be hard to find with a 7.3. I want something that gets decent fuel mileage but not something I have to constantly be tinkering with or worried about its reliability. I wont be hauling with it everyday but I will occasionally be pulling a 24ft trailer loaded with a tractor or full of other junk. Any input is great. Thanks.
mtitz is offline
post #2 of 5 Old 10-22-2013, 08:32 PM
fr9090's Avatar
Quoted: 4 Post(s)
I have both. 7.3 are a tank but a 6.4 is just as much a tank if you take your time to search for the right one. I'd take my time for a 6.4 if I were you. You won't regret it
fr9090 is offline
post #3 of 5 Old 10-22-2013, 08:46 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
There was just a thread on this 2 days ago. And there's many more. Have you not searched about this yet? Things to think about when going to a 6.4- can you afford a cab off procedure and the expense of doing other mods / replacement of parts while the cab is off? Are you going to work on the truck yourself or have somebody else do it? The 7.3 and 6.0 are easier to work on vs a 6.4 / 6.7. The 7.3 has been around for a while and parts are cheaper and more abundant versus the 6.4. Just depends on your lifestyle and deepness or shallowness of your wallet. I loved my 6.4 but I didn't have a big truck fund set aside for when **** hits the fan. The 7.3 fits my lifestyle and bank account better. This isn't the case for everybody obviously.
Search the forum in each section for the what you posted and you'll get good info.
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #4 of 5 Old 10-22-2013, 09:35 PM
Beewoody's Avatar
X2
05 F-250 SD Crew Cab Lariat 6.0 PSD: BPD Oil Cooler, BPD Manual Fan Clutch Adapter with 7.3 fan, Built FICM powerboard w/Atlas 40, Gearhead's SRL, 8k Tow, Unlimited Tune, EGR Delete, Blue Spring Mod, 6.4 Banjo, Updated HPOP/STC, Updated Standpipes/Dummy Plugs, EC-1 ELC Coolant, Updated Turbo oil supply/return lines, Edge CT, 2.5" Readylift Level Stage 3, 35/ 12.5/ 18 TOYO AT2 Extems' mounted on 18" MB wheels and finally.... STOCK HEAD GASKETS
.... 203K miles on 10/3/2014...
Beewoody is offline
post #5 of 5 Old 10-23-2013, 09:56 PM
PSDx's Avatar
x333333333333333333
2001 F-350 CC Lariat 7.3
-Superchips Flashpaq
-5" MBRP Turbo Back
- Pro Comp 4" lifts
- Method Standard wheels 16"
- Toyo mud terrains 35"
-Work in progress
PSDx is offline
