7.3l performance build questions! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-21-2013, 09:01 PM Thread Starter
HunterER7's Avatar
Well I've got an 02 crew cab. Stock everything . The truck needs injectors as it sits. I'm looking to replace the injectors and build some performance out of this motor while I'm at it.
Can someone point me in the right direction or a list of parts to get. Looking to get as much horsepower as possible with about $4-5k to play with.
Thanks, earl.
HunterER7 is offline
post #2 of 3 Old 10-24-2013, 11:19 AM
silverbullet4x4's Avatar
You would benefit from searching around here and also checking out the 7.3 performance section.
05 6.uh oh F250 <--SOLD
06 Jetta tdi<--Daily
6.4 Dreams, 7.3 Budget
TRUCKLESS
silverbullet4x4 is offline
post #3 of 3 Old 10-24-2013, 02:40 PM
JSchuricht's Avatar
Most of what you do will depend on what you have already done. For instance, do you have a transmission that can hold the power and gauges to monitor everything?
JSchuricht is offline
