Frame differences and snow plow mount - Ford Powerstroke Diesel Forum
Old 07-15-2008, 05:23 AM
Hey guys,
One of my companies 2001 5.4 F-250's is on it's last leg. It has over 200,000 hard miles on it and two of the cylinders are below 50psi on a compression check.
Anyways, we just put a brand new Fisher v-plow on it last season and are wanting to take it off to put on another truck. We're not sure what it will bolt up to though since the guy that put the plow on said he had a hard time getting the right mounting system for this year truck. Does anybody know what years they changed the frames on these trucks and how that effects the plow mount?
Old 07-15-2008, 05:26 AM
an 01 an 02 should be the same as far as that goes
Old 07-15-2008, 05:29 AM
Ole White
I agree it should bolt right up
Old 07-15-2008, 12:10 PM
Any idea if it might bolt up to a 03-04? I'm figuring things might have changed up front for the 05+ since they went to coil front ends.
Old 07-15-2008, 12:29 PM
Ole White
03-04 will work also and the frame on the 05-08 is the same also but the mount could be different for the Plow since its Coil Spring front end 05-08
