Oil Leak, Need Some Help - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-12-2008, 09:16 AM Thread Starter
Nally7.3Powerstroke's Avatar
Question Oil Leak, Need Some Help
After parking my truck I usually notice a couple drops of oil right under the oil pan on the ground. I am not sure why it's leaking and cannot tell where it's coming from. Anyone have any ideas?
Nally7.3Powerstroke is offline
post #2 of 10 Old 07-12-2008, 10:10 AM Thread Starter
post #3 of 10 Old 07-12-2008, 10:25 AM
International Threat
Marty's Avatar
Look on top, and the tech files has stuff for you.
How far from North East are you?
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #4 of 10 Old 07-12-2008, 10:29 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
check for the obvious things first.
My tech told me i had a leaking bed plate (big $$$) and it turned out to be the drain plug leaking.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #5 of 10 Old 07-12-2008, 10:29 AM
Marty's Avatar
http://www.powerstroke.org/forum/7-3...diagnosis.html
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #6 of 10 Old 07-12-2008, 10:35 AM Thread Starter
I live in northern Baltimore County, about 20 minutes from the PA line.
post #7 of 10 Old 07-12-2008, 10:47 AM
Marty's Avatar
Doesn't really help me LMAO... How far are you from elkton/North East area?
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #8 of 10 Old 07-12-2008, 10:55 AM Thread Starter
Mapquest says I am 1 hour away from Elkton, but I'm not sure where you are coming from so it might be slightly different.
post #9 of 10 Old 07-12-2008, 10:59 AM
Marty's Avatar
Well get some #5 O rings to the track and I'll check it out for you
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #10 of 10 Old 07-12-2008, 11:00 AM Thread Starter
Thanks, I appreciate it.
