Used Super Duty - Hitch Welded to Frame? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-10-2008, 07:08 PM Thread Starter
In looking at an otherwise nice 2001 F250 PSD SuperDuty at a Ford Dealership...I see the previous owner decided to purchase an expensive truck and then make a "homemade" gooseneck hitch. Why??? Who knows. The peace of mind from purchasing a quality and proven hitch to bolt onto a chassis is the only way to go if you're taking the risk of towing on public roadways.
Anyhow...it appears the hitch, albeit decent looking, has been welded to the frame. Basically they laid a piece of flat stock atop the frame rail and welded a cross member to that stock. Then welded the flat stock to the frame. Its welded on each end of the stock, along the side, right where the frame vertical web makes its curve to the top flat section flange. About 2" of weld each end, each side of the truck. Nice welds however.
Could a person simply remove the bed (for proper access and finishing) and take a sawzall or wheel and carefully cut through the weld and remove this? Then grind the remainder of the weld flush and gone?
Does anybody think the frame could have suffered untold damage or stress that would result in future failure? Or can the SD frames take this?
I seem to remember the upfitters guide on a F550 cab chassis saying not to weld except rear of the rear spring mounts. Even then you had to unplug the ECM and ABS modules...and disconnect the batteries and ground next to the weld area.
Any future problems could prove costly or "cost impossible" I think. Obviously a new frame is one of those over the top fixes. Thanks!!
neil is offline
post #2 of 16 Old 07-10-2008, 07:17 PM
duct tape & zip ties
bigcountrysg's Avatar
I don't think a saw zaw will cut through that metal. But I maybe wrong. What I would do is not worry about the frame area. If you want that hitch gone, I would take a cutting torch and cut the hitch off and leave the part welded to the frame intact.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 16 Old 07-10-2008, 07:23 PM
If you really want it gone, you could remove the bed as you say for better access and do the cutting with a sawzall or cutting disk in a grinder or even a torch. The frame between the rear leaf hangers doesn't really carry a lot of load. I am a structural engineer, and the welds you mention wouldn't scare me much.
99 1/2 CC 4x4 dually Lariat A/T 4.10s w/63k miles
Mods-Tymar intake, DP-Tuner , Autometer gauges, zoodad and 4" Bully Dog Exhaust.
Other toys- 88 Suzuki Samurai 4x4 lifted 6"
Polaris 500 HO RSE 4x4 and Yellow 700 4x4
05 Jeep Liberty Limited CRD 4x4
Gig'em! '86 Texas Aggie
Mykol is offline
post #4 of 16 Old 07-10-2008, 07:33 PM
cchase's Avatar
i weld on my truck all the time, i never disconect anything. Id be alot that a sawzall would prove useless for this. torch the weld, or grind it. but id just take the ball out and call it a day. plus you get to leave your bed in.
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #5 of 16 Old 07-10-2008, 08:35 PM Thread Starter
I'm fairly certain I can sawzall with the proper blade. But either way a thin disk air wheel is fine too. Whichever works. Be sure that I do not intend to cut into the original frame at all.
Basically I'm cutting through the weld just above the "parent" metal of the frame. So when I'm done grinding, the filler metal (from the weld wire or stick process) would still be present in the frame material. I'm thinking about grinding it smooth then painting so you can never tell it was on there.
I'm a civil engineer...and took several advanced classes 10 years ago (or so) on mechanics of materials. But this is the real world. And I have used the AWS manual for welding specs on several jobs were we needed structural steel installed. Plus I've welded and been around alot of welding. But I'll claim to be no expert in this area. I do know welding is really alot more complicated than some believe if you want it to be "exact" or "proper". I'm guessing this job was not looked into much...cause if it was...they wouldn't have done it considering the other better alternatives and ease of doing so.
I'm just not familiar with the SDuty frame material, nor what rods were used, whether it was preheated etc. It might be a cruddy weld afterall. I just don't know if the frame material was altered drastically from the heat of welding.
I know some trucks like the 03 up rams definately say NO NO NO welding for strength purposes.
I'm not really scared of the end result I'd get. But I'm worried about what I don't know on truck frames. I see alot of semi's in traffic that have decals ont he frames saying "NO WELD".
I'm thinking that portion of the frame area would usually see tension...which is bad for stress crack formation. But any loads would probably be small and not create any stress cracks unless I was hauling heavy. But one never knows what they'll be hauling.
neil is offline
post #6 of 16 Old 07-10-2008, 09:11 PM
It will deffinately have an aspect for frame flex if you were off-roading the truck. I would still just cut the hitch off flush with the frame and not worry about what is welded to the frame. But that is me. Also if you cut it flush with the frame it is easier then trying to cut or grind through the weld.
2002 7.3L burnt
post #7 of 16 Old 07-10-2008, 10:30 PM
regor's Avatar
I would just do as bigcountrysg said, cut it off and leave the plate on the frame and cut the rest off.
Roger
2006 F250 Superduty 6.0L 6 speed manual
MODS
Banks with PDA, Iron Horse Bumper,Upfitter switches, High Idol Mod, Zoodad, Tint, K/C Lights, 08 F250 Rims, Remote start and Viper Alarm, 03 Turbo, Electric exhaust cutout, ARP Studs and EGR Delete Thanks To Scott @ Trucks Unlimited
Coming Attractions
SCT Custom Tuning
regor is offline
post #8 of 16 Old 07-11-2008, 12:16 AM
my truck has the same sort of set-up 1/2 plate about 8 inches wide and angle iron running the length of the plate on each side on the bottom. Who ever did it sure laid down some weld. I don't even think twice about pulling my 30ft gooseneck. I say leave it if its not in the way.
larson0290 is offline
post #9 of 16 Old 07-11-2008, 12:32 AM
lilredpowerstroke's Avatar
If you are that worried about it then why dont you find another truck?? The reason someone would build their own is because they can. All of our ranch trucks have the gooseneck plates welded in and belive me when I say they tow heavy and have never had any problems.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #10 of 16 Old 07-11-2008, 04:07 AM
mrnecsteve's Avatar
The tough part about what you are trying to determine is you dont know what type of weld stick the operator was using or whether the cooling process was correct.
With a sawzall and lots of lube...I'll bet you can cut it!
mrnecsteve is offline
