2013 new model ELM327 Bluetooth OBD2 CAN-BUS Scanner Tool with Switch Work with Andro - Ford Powerstroke Diesel Forum
  #1
Old 09-26-2013, 02:38 AM
2013 new model ELM327 Bluetooth OBD2 CAN-BUS Scanner Tool with Switch Work with Android
Features:
OBD SCAN is the newly developed wireless scan tool. It supports all OBD-II protocols
0. Automatic
1. SAE J1850 PWM(41. 6Kbaud)
2. SAE J1850 VPW(10. 4Kbaud)
3. ISO9141-2(5 baud init,10. 4Kbaud)
4. ISO14230-4 KWP(5 baud init,10. 4 Kbaud)
5. ISO14230-4 KWP(fast init,10. 4 Kbaud)
6. ISO15765-4 CAN(11bit ID,500 Kbaud)
7. ISO15765-4 CAN(29bit ID,500 Kbaud)
8. ISO15765-4 CAN(11bit ID,250 Kbaud)
9. ISO15765-4 CAN(29bit ID,250 Kbaud)
A. SAE J1939 CAN(29bit ID,250*Kbaud)
B. USER1 CAN(11*bit ID,125*Kbaud)
C. USER2 CAN(11*bit ID,50*kbaud)
*default settings(user adjustable)
1. Works with all OBD-II compliant vehicles
2. Wireless (Bluetooth) 5~10 meter
3. Software included for Palm, PDA,Mobile
4. Software included for Windows PC
5. Software included for Windows Smartphone
Functions:
1. Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
2. Clear trouble codes and turn off the MIL ("Check Engine" light)
3. Display current sensor data, including:
4. Engine RPM
5. Calculated Load Value
6. Coolant Temperature
7. Fuel System Status
8. Vehicle Speed
9. Short Term Fuel Trim
10. Long Term Fuel Trim
11. Intake Manifold Pressure
12. Timing Advance
13. Intake Air Temperature
14. Air Flow Rate
15. Absolute Throttle Position
16. Oxygen sensor voltages/associated short term fuel trims
17. Fuel System status
18. Fuel Pressure
19. Many others. . .
Output Protocol: RS232 to bluetooth
Frequancy: 38400
Voltage: 12V
Current: 45mA
Bluetooth: 10m
Switch: YES
Supported platform: Android, Symbian, Windows Mobile, palm, pc, pocket pc
Software:
1. For Android: Torque+1.5.58+
2. For Symbian: OBDScope V1.21
For WindowMobile-palm-pc-pocket pc:
3. ScanMaster--ELM v2.1-pc
4. PCMSCAN-pc
5. OBD2Spy
6. ELM327-V1.2-pc
7. EasyOBDII
8. wOBDCRAZY
Software CD is included.
Net Weight: 44.6g
If you want to more detail on ELM327 ,you can email to sales@obd2tool.com
Reply With Quote Quick reply to this message
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.1
