Starting issue on 2000 f250 7.3 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-23-2013, 06:43 AM Thread Starter
I installed a new starter and new battery's, truck ran great all weekend, went to start it this morning, engine continuously turns over but no start! Anybody have any idea what this may be?
Powerstrokedude1 is offline
post #2 of 2 Old 09-23-2013, 08:10 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
It could be several things, cps, fuel pump, glow plugs, hpop, IDM, PCM.
First of all check your fuses could be as simple as that.
Next check the CPS(Genuine Ford 7.3L Diesel Cam Position Sensor (CPS) - Blue) This sensor going bad can cause a whole plethora of strange problems for the 7.3 and is cheap/easy to change as a first measure
Next best thing to check is if your glow plugs are getting power ([Troubleshooting GPR & GP's)
Then next check your fuel pressure it should be if i remember correct AT LEAST 35 psi(could be wrong if someone wants to correct) to even fire and 65 psi is optimal for a stock truck.
Next find another working IDM from any truck from 94-03 7.3, they are all compatible then swap it in to see if it starts. That will tell you you need another IDM
Next would be to check your HPOP reservoir oil level. It should be within an inch from the top of the reservoir check port. That would signal a weak hpop/lpop. Best way to test is if you can get your hands on a scanner than can read live data from the truck. The HPOP needs to be at least 500 psi to let the truck fire the injectors.
Thats just a few of the common causes for no start, by no means is it 100% but it will get you a start
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
