basic maintenance - Ford Powerstroke Diesel Forum
Old 12-14-2005, 07:53 PM
basic maintenance
What do you guys do for general maintenance besides oil changes? what about draining water from fuel filters and stuff like that, is there anything else that falls under basic maint for a diesel? any input would be nice, thanks..
Old 12-14-2005, 08:06 PM
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Well I have had my truck for over a year now and still haven't drained my water separator. But the light hasn't come on for it yet. I should do it soon anyway. I'd make sure you pump in some nice fresh grease into all your zerk fittings. I use marine grease, I just think it's better.
Old 12-15-2005, 06:40 AM
Send a message via MSN to Turbo Rushmmm
Where do you drain the water at? I know there is one there just not aware of the location. still learning
Old 12-15-2005, 01:55 PM
Change the fuel filter every 10K to 15K and check the air filter.
Old 12-15-2005, 06:41 PM
oil changes every 3-5 thousand every 20 thousand change fuel and once a year change tranny fluid, I haul 40' toy hauler fifth wheel, never had problem
Old 12-15-2005, 06:49 PM
oil changes every 3-5 thousand every 20 thousand change fuel and once a year change tranny fluid, I haul 40' toy hauler fifth wheel, never had problem . 02 ford crew cab longbed banks trans command, k&n fipk, edge evolution and edge juice with lcd monitor, 4" turbo back exhaust,
