Glow Shift gauges and gauge pod, review - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-08-2013, 05:59 AM Thread Starter
I recently installed the Glow Shift gauge pod (4 pod) and gauges into my 2001 Ford Excursion. The gauges look nice, have pleasing fonts on them and they dim decently for night driving. So far, the only complaint I have, and it's a BIG one, is the positioning of the gauges. They are rotated to approximately the 4 o'clock position, instead of being straight down from the pillar at the 6 o'clock position. This rotation does two bad things:
1. it blocks even more of the windshield view near the pillar. The pillars in these trucks are relatively large, and already block out some visibility while driving or turning left. The new gauge pod position adds another 2-3" where you can't see clearly, and have to lean up and forward to now view what may or may not be in your path. This sucks for me.
2. it blocks the sun visor. You can pull down the visor just about half-way, and then it hits the gauges with about a 1.5-2" flap. the only way to get the visor down farther is to unhinge it from the center clip, turn it like you want to block the driver's window, swing it down, over the gauges, then push it back into position and reattach the end to the clip in the center of the roof. Then, to put it back up, you have to do the reverse of that process. This sucks for me as well.
This is enough of a pain that I'm going to start looking for a gauge pod that orients them down into the 6 o'clock position as both of those items above are safety issues. Yeah, some people may consider them minor inconveniences, but if you end up getting into an accident due to either of those, you'd wish you didn't have those problems to begin with. As a guy getting older with a family that I haul around a lot, I realize more and more the importance of good visibility and not having to be distracted while driving (and fiddling with the sun visor is enough of a distraction to be potentially dangerous).
Anybody know of a 4-gauge pod that hangs in the 6 o'clock position?
billyrb is offline
post #2 of 12 Old 09-08-2013, 02:32 PM
william_ace's Avatar
Quoted: 2 Post(s)
This is interesting to me. I was looking at getting a few of the glowshift guages as well. I am interested to see if others have had this problem as well. Keep us updated!
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #3 of 12 Old 09-08-2013, 03:17 PM
F350Bigfoot's Avatar
I installed the 3 gauge pod and don't have any problems with any blocking or it hitting anything.
F350Bigfoot is offline
post #4 of 12 Old 09-08-2013, 04:43 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Same here no problems like his at all.I love mine
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #5 of 12 Old 09-09-2013, 04:52 AM Thread Starter
the 3-pods don't have this problem, as it is the 4th pod that interferes. The 3-pod has the lowest pod down in the same spot as the 4-pod units.
billyrb is offline
post #6 of 12 Old 09-09-2013, 05:53 PM
Ahh I see your problem. Short of maybe trimming it a little bit to adjust it not sure what you could do.
post #7 of 12 Old 09-10-2013, 06:11 AM Thread Starter
it would have to have a couple inches removed, then resewn (and would look like crap)
billyrb is offline
post #8 of 12 Old 09-10-2013, 02:05 PM
Got any pics?
post #9 of 12 Old 09-10-2013, 02:58 PM
I have the Glowshift 4 gauge pod and love it.
In common language:
My visor has a little (flappy thing) on the left hand side that allows the visor to clear the upper gauge when lowering it all the way against the windshield.
In more technical language:
My visor has a crease which allows it to sit flush against the headliner when in the stowed position. This crease also enables me to move my visor all the way forward against the windshield.
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
post #10 of 12 Old 09-11-2013, 06:07 AM Thread Starter
Here are some pics. I can work around both issues, and 'could' add a crease, but shouldn't have to essentially wreck the visor and internal board to make it work. The two items are safety concerns, and what ticks me off the most is that neither of those two items were mentioned in any of their ads, website, literature, installation instructions, etc. And, their customer service basically came back with 'its an aftermarket part, so you have to expect this kind of stuff'. I co-own a business that sell aftermarket parts, and from a legal standpoint we always mention when something may block visibility, or block a safety related device on the vehicle.
As soon as I find a 4-gauge pod that puts them oriented farther down (which would be safer and more aesthetically pleasing too), I'll switch. I like the gauges, the colors, the display, and also like the pod finish / color / texture. It's just the orientation that causes issues for me. Oh, and as others have mentioned, as a tall guy (6'-2"), I can't see the lower portion of the upper two gauges without lifting up out of the seat. They have all 4 pod holders angled up. My guess is they angled the lowest pod, and then took a mold of that and used it for the other 3 upper pods, without considering that they needed to angle each one a little down as they went up the assembly.
billyrb is offline
