Where to get CB installed? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-28-2008, 10:15 AM Thread Starter
Well, my brother got me a CB radio for Christmas, and I'm looking to hook it up soon. I would do it myself, but have been strapped for time lately. I was thinking about Best Buy maybe? If I did do it myself, what do I use to hook up the antennas to the radio, like speaker wire? Sorry, but I've never really worked on electronics before, just dirt bikes lol
07 Red F-250 CC SB PowerStrokeDiesel
4 inch MBRP turbo back....no muffler, no cat
33 inch Pro Comp All Terrains
Texas Ranger CB Radio
07psd356 is offline
post #2 of 8 Old 05-28-2008, 10:30 AM
duct tape & zip ties
bigcountrysg's Avatar
I suggest you google cb shops in your area. Best buy wouldn't have a clue what to do.
Most antennas if they are magnet mount have the COAX (coaxile cable) already attached to them.
If you need to buy coax you need at least rg-8 to run from the antenna to the radio. You will also have to get the antenna and radio matched. To do this you need an SWR meter. Best thing to do is just find a cb shop near by and have them do it. They usually charge around 40 bucks to install and match a radio to an atenna. If you install the radio and the antenna and take it to them for matching then it usually costs around 20 dollars.
Some places charge around 60 dollars to peak and tune your radio, install radio, and then match the antenna.
Some antennas to look at if you need to buy one.
Magnet Mounts
K40
Wilson 1,000
Standard Mount
Wilson trucker 2000
102" stainless steel whip with load spring.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 8 Old 05-28-2008, 10:50 AM Thread Starter
I believe that the antennas I have are 4 foot Fire Sticks. I have the mounts, to hook them up in the bed, but need to run the wire through the back window. I could mount it, I just have no idea where. Where does everybody else have their's?
Well it looks like there aren't any shops close by, do you know where I can pick up a SWR meter?
07psd356 is offline
post #4 of 8 Old 05-29-2008, 12:58 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I have my antenna mounted on my tool box on the side. Before I had a toolbox, I had it mounted in the stake hole in the bed. Any CB shop should have the mounting kits. And wire it up yourself. It won't take you long. Maybe an hour tops. Also, my Cobra 29 has a built in SWR meter...
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #5 of 8 Old 05-29-2008, 01:04 PM
strokermann's Avatar
radio shack has the swr meters. and i wouldn't trust the swr meter on the radio. i would persoanlly run a wilson 1000 or 5k good antennas and the higher the better. fire sticks are garbage and hard to tune and there below the cab.
CB Radio- General Lee
7.3l 99 f-250 SD
4 INCH TURBO BACK TO 6 INCH MITER CUT STACKS CURIOSTY OF GRAND ROCK AND COWBOY DIESEL PERFORMANCE.
TS 6 POSTION CHIP. stock,high idle,50,75,100,140hp.
strokermann is offline
post #6 of 8 Old 05-29-2008, 01:06 PM
The best way to get all your answers taken care of is.....find a truck stop on the highway,...ask someone where the closest CB shop is....and go there.
Most likely it will be run by a guy older than Dinosuars,...but he'll be able to answer every qyestion you'll ever have.
TANK'S 250 is offline
post #7 of 8 Old 05-29-2008, 01:11 PM
Justinlw's Avatar
Quoted: 28 Post(s)
Send a message via MSN to Justinlw
I wouldn't trust Best Buy to install a cd in my cd player. Those guys are usually just out of high school, with a little driveway install experience. There are a couple good ones, emphasis on a couple.
2010 F250 Lariat FX4 6.4l
Carli Backcountry 2.5", 11+ Leaf Springs, SCT 3015R/Tyrant Tuned, Edge Insight CTS,
FloPro DPF Pipe, RCD EGR Delete/Elbow, Sinister Coolant Filter, 11+ Console
Justinlw is offline
post #8 of 8 Old 05-29-2008, 01:15 PM
RedDye01's Avatar
You can get any of the parts at a Love's or Flying J filling station. They probably wont show up on google if you're just searching for CB shop.
Bellowed Up Pipes
GTP38R
T500 HPOP
HPX Line
RiffRaff FRX Line
JW Valve Body
4" Lift w/33's
6637 DIY intake
4" exhaust
Gauge
RedDye01 is offline
