strobes - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-18-2008, 08:08 PM Thread Starter
AvroAero's Avatar
strobes
Was wondering if anyone was running strobes in their rigs. I want to put some in the front clearance and the rear reverses and was wondering if you need to drill a hole in the reflector to mount these things. Post some pics if you have any
thanks
2004 Ford Excursion 6.0
-SCT livewire w/ innovative extreme tunes
-Banks monster exhaust
-Zoodad
-05 conversion w/ harley headlamps & HIDs
-Viper 5900 remotestart/alarm
-ARP studs
-EGR delete
-Defender roof rack with 600W of light
-whelen hideaway strobes
-Sound off Predator dual red-red
-Whelen 500 4 amber 2 blue
AvroAero is offline
post #2 of 10 Old 05-18-2008, 08:11 PM
cchase's Avatar
You do need to drill. I used a one inch bore bit. make sure you check your local laws with the rear strobe, some areas will only allow you to have red. no pictures, because mine broke and i havent replaced them yet
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #3 of 10 Old 05-18-2008, 08:12 PM
a truck
Matt P's Avatar
Yeah I got strobes on both my trucks, on my Powerstroke I have the LEDs and have two mounted in my grill and two on my rear bumper and planning on adding four more. On my 86 F150 I have 6 I have them in my tailights, front turn signals and two in my grill, and yes if you want to put them in those lights you will have to drill into them becuase the strobe light is a separate light unless you just get headlight and tailight flashers, heres some pics
03 king ranch w/ a cummins
Matt P is offline
post #4 of 10 Old 05-18-2008, 08:19 PM
Jonnie_Knuckles's Avatar
i wanna throw some in my truck - how much does a normal setup run???? ---- like police style strobes....
Race In Peace Travis Bestwick Aka "Tito Motha****in' B."
May 29, 1983 - June 22, 2008
2002 F250 SD 7.3
Jonnie_Knuckles is offline
post #5 of 10 Old 05-18-2008, 08:24 PM
a truck
Matt P's Avatar
If you want LEDs the ones that I have are 50 a piece, the type of strobes in my other truck require a box which is like 250 plus about 20 for each bulb, check out strobesnmore.com thats where I get everything
Matt P is offline
post #6 of 10 Old 05-19-2008, 08:37 AM Thread Starter
AvroAero's Avatar
Do you ever get problems of water/condesation getting into the light from the strobes?
-Zoodad
-ARP studs
-EGR delete
AvroAero is offline
post #7 of 10 Old 05-19-2008, 04:37 PM
cchase's Avatar
my front did. but it happened offroading. its a pain to get right again. it also caused my strobes to short and a small fire.
but at work I drive
7 Duramaxes
NO CUMMINS.....
cchase is offline
post #8 of 10 Old 05-19-2008, 04:38 PM
Marine Raiders>Seals
najaf4life's Avatar
contact ABOBB.. Aaron has a set on his truck...
RYAN
03 Excursion 6.0L
BPD,WPE & other odds and ends
najaf4life is offline
post #9 of 10 Old 05-19-2008, 04:51 PM
a truck
Matt P's Avatar
With the LEDs I never have to worry about water cuase they come pre sealed, for the ones in your tailights or clearance lights just get silitcone caulk for the seams and you wont have to worry about the water then
Matt P is offline
post #10 of 10 Old 05-19-2008, 06:03 PM
Is it even worth it???
ABOBB's Avatar
As my signature says.. I have Whelen's 90 watt strobe kit on my truck.
I really like it. Had some help with the install, but it's pretty straight forward.
It did require coring 1" holes into the light reflectors. However, every strobe "head" I've had so far seals very tightly, and I've seen very little moisture inside of the housings.
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
