Help selecting first F350 power stroke - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-19-2013, 11:38 AM Thread Starter
BLACKMONGOOSE's Avatar
Hey Guys. New guy here. I am purchasing my first powerstroke and need some help finding my way as I have been overwhelmed with all the different configs from 99-2013.
I have been researching this off and on for months and this forum has been excellent. Thank you all.
I am looking at an F350 crewcab fullsize drw. 2wd preferred. I cannot decide between an older 99-2002 and their legendary 7.3L or the newer 6.7L with their stump pulling 800ft/lbs, 6 spd, and engine brake. And, although this may not be the best way to start off a thread on a power stroke forum, the 6L is off the table for me (sorry 6L fans; no offense intended)!
I currently tow a TT at about 5800lbs loaded and also pull a 20ft enclosed car hauler loaded with a sand rail and gear or classic cars (haven't weighed that yet) and 2 growing boys. Both towing situations are new to me as of Jan of this year but have already lost track of the number of trips.
Since this is really the beginning of towing for us going bigger on the TT side is likely and, since I keep my vehicles at least 10 years on average, I plan on keeping this truck until there is nothing left of it. (After all how much more truck can a guy need!)
I am thinking drw because of better handling and load capabilities but realize I am no where near load cap even for a F250 let alone a 350 drw. Again, keeping this truck a LONG time.
We run a lot of BIG hills and winding roads as well and a lot wet roads here in Oregon. Not much snow.
Here are my questions:
99-02 vs 09-12? Can I get away with the older? Are the 09-12 really worth the money? 4 spd vs 6? Is the 300 ft/lbs of torque difference a deal breaker? In my area the older goes for $20ish fully loaded and has right at 100k mi. and are like new (one owner). The newer goes for $35-45k fully loaded, around 6K mi. and up.
The bottom line is I don't want to over buy with the newer nor do I want to spend a lot of time and money making the older perform like the newer. I can afford either; just trying to be practical.
Thoughts? Links to other post appreciated. Thanks for putting up with the new guy. Appreciate your input.
BLACKMONGOOSE is offline
post #2 of 2 Old 08-19-2013, 11:58 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
well, you can do some minor things to the 7.3L(switch on the fly chip with good tow tuning, exhaust, intake, maybe a trans cooler) and do very well with it. the 6.7 or 6.4 is going to be more comfortable(by far) ride better, quieter engine and have a little more power out the box. i guess it all boils down to do you want one with a factory warranty? do you mind working on one with your own hands when it does go down for repairs(7.3 most likely). do you like the louder engine, or the quieter engine? the emmissions crap gets me on the newer trucks. id rather not have all that stuff. the newer trucks haul really well in SRW form and have better GVWR vs the older trucks. heck you might get away with a 250 if you get a newer 08-12 truck. put you some air bags under the rear and it will pull like a dream.
just some thoughts for you to consider
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
