1997 vs 2000 f350 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-15-2013, 04:43 PM Thread Starter
1997 vs 2000 f350
im looking at getting a truck can someone give me the pros and cons of these i had a 97 and loved just wonderd whats the difference between them power ride quality noise any promblem areas anything would be great
rtm20012003 is offline
post #2 of 7 Old 08-15-2013, 05:21 PM
c69ss396's Avatar
00 is intercooled, more available power. better handling
97 looks better.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #3 of 7 Old 08-15-2013, 05:29 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
OBS
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #4 of 7 Old 08-16-2013, 08:56 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
OBS, no smog so sky's the limit. They are going up in value for this reason as newer trucks are going down.
You can mod a OBS to ride as good or better than any SD, interior swaps easy and have all the HP needed for the street .
My built OBS is quieter than my EB Excursion with single shots..
CT Performance, Inc. is offline
post #5 of 7 Old 08-19-2013, 03:31 PM Thread Starter
thanks for the info anyone else
post #6 of 7 Old 08-19-2013, 04:01 PM
alaskan155's Avatar
Quoted: 60 Post(s)
for 2000
pros
still no smog on it unless it has a cat from the factory(my 02 doesn't)
better interior/modern exterior
rear disc brakes
better turbo and intercooler 250hp stock
rear shackle on the rear of the front springs so a better ride
cons
higher insurance
Dana 50 on the 2000
unit bearings
wider/taller than a obs
97 f350
pros
Dana 60
serviceable wheel bearings
parts are cheap for it/easy to find,
cons
extend cab doesn't have doors for the rear
rear drum brakes
gvwr/gcwr might be lower than the SD(can't find specs for the OBS) something to consider if you plan on towing
those are the big ones i can think of, in the end they are both great trucks/good platforms, it basically depends weather you want a more modern truck or a older looking truck, both are 13+ years old,
out of the box, no upgrades
ride SD > OBS for 4wd for 2wd i would say =
power SD > OBS
Noise SD = OBS been a few years since i rode in a 7.3 obs but either way the 7.3 is a loud motor, noise can be fixed with sound deadening, like dynomat, or the cheap Home Depot special matting .
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #7 of 7 Old 10-21-2013, 02:07 PM Thread Starter
up to the top any more info
