How the %*(# - Ford Powerstroke Diesel Forum
Old 04-21-2008, 05:45 PM
How the %*(#
How the hell do you disconnect the fuel line from the gas tank.
Im replacing the front 19gal gas tank and the old one is dropped but i need to disconect the fuel lines from the sending unit so i can install a new retaining ring to keep the fuel sender retained to the gas tank.
I rented this fancy $250 tool with a billion parts and no instructions
I used the computer to put color on each different piece of where its suppose to disconnect
Old 04-21-2008, 05:50 PM
Send a message via Yahoo to twiztid1981
well i dont know what that tool is but i went to advanced an bought a lil plastic line romver for 2.50 an poped my lines off, your truck is obviousley older but im sure they got somethin for ya
Old 04-21-2008, 05:54 PM
duct tape & zip ties
The same tool will work for his truck too. He has the master mechanic a/c fuel line disconnect kit. Which should have the proper pieces to disconnect the lines. You just need to find the right size piece and go for it.
