Wiring LEDs please help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-16-2013, 08:50 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Ok guys i need help picking the right resistor to put in my led taillight project.
Heres what im looking to do. The red is the running lights and the dark red are the brake lights that come on when you push the brake.
Heres the specs of the LEDs
Diameter-5MM
Forward Voltage-3.0-3.2V
Current-20MA
Running in parallel with 18 leds in each circuit using a voltage regulator( 20 x L7812 7812 Voltage Regulator IC 12V 1 5A St USA Seller Free Shipping | eBay ) to maintain a constant 12v power source
What i want to know is what resistor do i use on the positive side of each column. The online resistor calculator says 27ohm 5.4W resistor but that one doesnt exist and most of the ones i find/have are only 1/4W so what would you guys use i dont really wanna spend 30 bucks in resistors theres gotta be a way to use the little 1/4 watt ones right?
If you know a better way to achieve the results in the picture by all means let me know
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 4 Old 07-16-2013, 04:18 PM
Quoted: 6 Post(s)
You may ask the LED manufacture that question.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #3 of 4 Old 07-17-2013, 05:38 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
post #4 of 4 Old 07-17-2013, 05:55 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Yes the first one is the one i used.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
