coolant flush - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-13-2013, 05:56 PM Thread Starter
coolant flush
do you have to take out the coolant drain plugs in the block to flush the system?
shrimpsnakes is offline
post #2 of 5 Old 07-15-2013, 02:07 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
No you don't but you don't get quite as much coolant out when you drain the system, therefore you have to flush more times to make up for it. It takes 6 flushes or 24 gals of distilled to completely flush the system.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 5 Old 10-07-2013, 09:10 AM
removal of engine plug?
I have tried removing engine plug using 8mm hex & it torqued way tight...any suggestions. If I cannot get broke loose?:
reddwarf is offline
post #4 of 5 Old 10-07-2013, 10:45 AM
If you can't get the plug out you may end up having to do the without draining the block. Make sure you do not do a chemical flush because you will clog your oil cooler. A flush with distilled water and then fill her up with the proper amount of ELC and you should be fine.
Ps.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #5 of 5 Old 10-07-2013, 05:07 PM
Used impact, it freed up
went to get restore at cummins, parts guy said:just use Plus a 2nd time(and sold me another gallon) I explained I was trying to flush silicates out...said just flush w/Plus again..did I get "hosed"?
reddwarf is offline
