Ficm help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-12-2013, 08:43 PM Thread Starter
Ficm help
I am getting problems with my 6.0 people
Are telling its my ficm..
Here are the problem:
After I had chane my oil on my truck I go to start it up I have to hold the key down on crack it for about 30sec..then it ran like it had a had no power until I got on the peddle after that it ran good
When to start it up in the morning it did the same thing only in the morning it does this..could it be the ficm or something else
808_6.0 is offline
post #2 of 2 Old 07-13-2013, 08:06 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1119 Post(s)
Feedback Score: 6 reviews
Could be a number of things. Have you physically checked the FICM voltage?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
