More power wanted . What mods do I need powerstroke 7.3 help me get more HP - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-11-2013, 05:37 PM Thread Starter
Hi all,
I have a 2003 F250 SD with the 7.3 PS Diesel and I have the following mods
GTP38R Garrett Turbo
Banks Power Elbow
4" SS Straight through exhaust
DP Tuner
K&N Filter
Custom built Auto transmission
I am wanting to know what to do next ??
LETS SPEND SOME MONEY : )
attached is a photo of my Truck : )
timthev8man is offline
post #2 of 11 Old 07-12-2013, 06:27 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
#1 DITCH the K&N!!!
#2 GoTo the 7.3 "99-03 Performance Parts Forum" below
NoRalPh is offline
post #3 of 11 Old 07-12-2013, 06:35 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
X2 on the K&N, get a Tymar intake, then stage 1's ...
Do you have a boost fooler?
Bellowed uppipes?
31 row trans cooler from a 6.0?
Guages?
Pm if I can help.
CT Performance, Inc. is offline
post #4 of 11 Old 07-18-2013, 04:56 PM Thread Starter
Bellowed uppipes?
Guages?
Pm if I can help.
Whats wrong with the KN ?
standard up pipes ... Do they really make a difference ?
No boost fooler ? Please explain ....
Yes to transcooler and also bigger trans sump for extra oil cap
guages are being planned now... Boost/Pyro/Trans oil
post #5 of 11 Old 07-18-2013, 05:04 PM
Quoted: 3 Post(s)
Bellowed uppipes don't use donut gaskets so no boost leaks.
The K&N element should be avoided in turbo-charged applications. The initial filtration efficiency is not high enough to protect the compressor impeller. Almost no one uses these in the offroad world as they just can't stop the dust...40+ year old tech.
There is an overboost code that reduces the cycle time of the IPR. The result is a slower gain in acceleration, not a reduction of fuel. The way to see if you are setting this would be to scan for the code. I run a MAP Pressure Relief Valve on all our builds. Some tuners can turn off the check engine light but you still have the issue.
post #6 of 11 Old 07-18-2013, 05:13 PM Thread Starter
Thanks for the advice......
I had a scanner on it and the only code that comes up is the Exhaust pressure control valve perform code when I perform a test scan ????
post #7 of 11 Old 07-18-2013, 05:46 PM
Quoted: 3 Post(s)
What is your max boost? A SD 7.3 after 22-24lbs will pull back the HPO.
post #8 of 11 Old 07-18-2013, 08:53 PM
AUSPowerstroke's Avatar
Another Aussie? Did you just buy this? Seen it for sale recently
2003 F250 7.3l (RHD), auto, 4"lift, 315/75R16's, arb steel winch bar, 12,000lb winch, 30" LEDlightbar and 2x lightforce 240 spotlights, Snorkel, edge cts attitude tuner, 5"stright through exhaust, Custom made rock sliders, Front and Rear ARB air lockers, still more on the list to be done
AUSPowerstroke is offline
post #9 of 11 Old 07-18-2013, 09:15 PM
69fastback's Avatar
Bellowed uppipes?
Guages?
Pm if I can help.
What are "stage 1s?". Stage 1 what?
what is "IPR?"
What is "HPO?"
69fastback is offline
post #10 of 11 Old 07-19-2013, 09:47 AM
Quoted: 3 Post(s)
Stage 1's are Injectors.
HPO ..High Pressure oil
IPR Injection pressure regulator
