Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
  #21 (permalink)
Old 04-11-2008, 10:36 AM
somebodyelse5 somebodyelse5 is offline
FREE is a great word. haha
  #22 (permalink)
Old 04-11-2008, 10:59 AM
stroker27 stroker27 is offline
Originally Posted by TANK'S 250 View Post
1. I definitly know I need to filter the water out.(do you know of a good water filter, that will filter small particules of water?)
TANK
check out the donaldson filter, im not sure if you can use it for your fuel
but you should be able too... also look at frantz filtering, they might have
some solutions for ya. now for the payment.... go ahead and ship me 300
gallons for the info i just gave ya.
  #23 (permalink)
Old 04-11-2008, 11:11 AM
Anthony2447 Anthony2447 is offline
<--Chicks Machine
Send a message via AIM to Anthony2447
Overseas we use JP-8 in everything, Its the only diesel we have on post. We use it in our HMMWV's MRAP's and Strykers, the air force and civilian contractors run in theyre 7.3's and 6.0's so i dont think youll have a problem running it stright
  #24 (permalink)
Old 04-13-2008, 06:04 PM
John_BZ John_BZ is offline
Originally Posted by 00f250 View Post
Thats 100LL (100 Octane Low-Lead). It has a blue tint to it. It does have some lead in it though.
yep. in "newer" unleaded vehicles running 100ll or 80/87 will foul up your valves with lead deposits. the lead is in there because it is still required for lubrication at higher altitudes. there are also other additives in 100ll suited for high altitude operation that might not jive with a regular gasser. that and 106 octane race gas is pretty close in price to 100ll, so i cant think of a good reason to run it in anything but the cessna 182rg's i fly.
  #25 (permalink)
Old 04-14-2008, 10:04 AM
Streak Streak is offline
Send a message via AIM to Streak
All I know is that Jet Fuel is at least $5 a gallon, so unless you are getting it surplus (defuels or who knows), it's getting stolen from somewhere...
  #26 (permalink)
Old 04-19-2008, 04:25 PM
TANK'S 250 TANK'S 250 is offline
It's not stolen,..it's defuels, and test samples
  #27 (permalink)
Old 04-19-2008, 09:13 PM
Okiefromwatonga Okiefromwatonga is offline
Serving Overseas
Send a message via Yahoo to Okiefromwatonga
JP-8 also has an antimicrobial additive in it (called prist I beleive).
  #28 (permalink)
Old 04-19-2008, 09:16 PM
I don't if it does...sure couldn't hurt.
"JET A-1 fuel is essentially identical to JP-8 except it does not have three additives required in JP-8: a fuel system icing inhibitor, a corrosion inhibitor, and a static dissipater additive. Hot JP-8 fuel reduces the life of fuel pumps on some diesel engines, so avoid using JP-8 or Jet A-1 extensively in hot heather, and keep the fuel tank as full as possible to reduce fuel temperature.
Diesel fuel #2 and water separate completely; JP-8 fuel and water do not. JP-8 becomes cloudy when contaminated with water; and the cloudier the fuel, the more severe the contamination."
  #29 (permalink)
Old 11-06-2009, 02:42 PM
mytruckbroke mytruckbroke is offline
JP-8 is super clean diesel fuel.
our forklifts run only jp-8 cause they are indoors.
diesel would kill us all in a closed building.
before jp-8 we used jp-5. they never add anything to them only fuel and go.
i would add 2 cycle oil if it was me but i do that now on green fuel.
fuel from defuels and samples would be great. you could put it in a small skid tank with a water separator filter on the pump like i use on farm equipment with red fuel.
it gets the crud and water out. just open the tap on the bottom of the filter and drain the water every so often.
