Rotella Ultra ELC. FOUND!!! - Ford Powerstroke Diesel Forum
post #1 of 25 Old 06-27-2013, 08:27 PM Thread Starter
6pointOHHH's Avatar
Thumbs up Rotella Ultra ELC. FOUND!!!
So in getting all my stuff together to do a coolant flush, EGR delete, and few other mods at once to my "New To Me '04 F350 CC", I began researching ELC coolant types. Based on my amateur research I came to the conclusion that Rotella Ultra ELC is some of the best stuff out there.
Began looking all over the web and could not find the stuff anywhere! Was about to pull the trigger on some Cat ELC, when I stumbled across this ...
Rotella Ultra ELC Antifreeze-Coolant Concentrate
Pricey ... but I'm happy to have found it. So if you or anyone else is looking for the stuff, there you go.
2004 F-350 CC SRW FX4 Lariat
-ARP Studs
-IPR Gen 2 EGR Delete w/up-pipe
-IPR Extreme HPOP Screen
-Wicked Wheel 2 on stock turbo
-MBRP 4" SS NC NM
-S&B CAI
-Blue Spring Upgrade
-Sinister Oil & Coolant Filter Kit
-Mag-Hytec Trans Pan and Rear Diff Cover
-Edge Insight CTS w/EGT
-Tekonsha P3
-Updated Turbo Oil Feed & Drain Tubes
-SCT SF3 w/Looney & Tow by Vivian
-Sony XAV701HD
-BedRug
-Rotella T6
-Rotella Ultra ELC Coolant
-High Idle Mod
-Diesel Turbo Lifesaver (came w/truck)
6pointOHHH is offline
post #2 of 25 Old 06-27-2013, 08:35 PM
Lilfarmrboy's Avatar
Actually they have this stuff stocked pretty good at most of the big name brand truck stops such as Pilot, Flying J, Loves, etc... Its a bear though if you don't live close to one. Some heavy industrial equipment repair shops have it in stock to or at truck repair shops. You just gotta look around for it.
Lilfarmrboy is offline
post #3 of 25 Old 06-27-2013, 09:55 PM Thread Starter
6pointOHHH's Avatar
Thanks. That's good to know, but unfortunately none are within a reasonable distance from me. Plus, I work a lot so the web is my primary point of purchases.
-ARP Studs
-MBRP 4" SS NC NM
-S&B CAI
-Tekonsha P3
-Sony XAV701HD
-BedRug
-Rotella T6
-High Idle Mod
post #4 of 25 Old 06-27-2013, 11:21 PM
ngaraiderman's Avatar
I went to 12 different truck stops in my area and none of them had the concentrate, only the 50/50 mix.
Finally got some Final Charge at O'Rileys. but, one store sai "I've never heard of that stuff, are you sure that it's real" I made a 180 and quickly left his O'Rileys. Went to the one next town over and he said of course we have that. Gave me the 2 gallons he had and said " I will order a case and it will be in by 11am tomorrow, just stop back by".
I guess some people just dont have a clue.
That price seems about right. Mine was $25 a gallon
ngaraiderman is offline
post #5 of 25 Old 06-28-2013, 03:33 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Awesome! That is pricey. But ill grab some for the next time i change my coolant!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #6 of 25 Old 06-28-2013, 05:40 PM
Correction it may not have been the concentrate. I will look more closely when I head back out for two weeks on Monday. But for those who do have the time try the local heavy equipment dealers or the truck repair shops. At least the ones here in Delaware usually have a couple of gallons on hand at any giving time.
post #7 of 25 Old 06-28-2013, 07:32 PM
Here is the one I used
post #8 of 25 Old 03-20-2014, 12:32 PM
jluv's Avatar
Quoted: 11 Post(s)
Thank you for this thread! I have searched high and low and can't find Rotella Ultra ELC anywhere near me, and I live in DFW! I get the strangest responses when I ask for it. Either they never heard of it, only carry the 50/50 mix, etc. The guy at the local Autozone said "Antifreeze is antifreeze. Always has been."
Geez.
jluv is offline
post #9 of 25 Old 05-08-2014, 09:05 PM
Maxxforce365's Avatar
Quoted: 14 Post(s)
Geez.
We carry this stuff all day at our dealership in Ft Worth and Dallas
Instagram@platinum_forces
2015 Platinum F350 CCLB[/B]
EPA Delete Tuned by PIP
Fabtech 12" 4 Link Airdog II
04.5 F350 CCLB 4/04-7/25/15
MTW S2 Warren 175/30s Tuned by Gearhead
ARPs with OEM gaskets
Sinister Regulated Return AirDog II Beans sump
2012 Door Panels Fully Functional
Warn 12k winch
Fab Fours Front and Rear bumpers
Maxxforce365 is offline
post #10 of 25 Old 06-30-2014, 07:19 PM
jluv's Avatar
Quoted: 11 Post(s)
What dealership are you referring to? Anything close to Mansfield or Grapevine? I need another bottle or two.
jluv is offline
