Transmission - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-02-2013, 06:17 AM Thread Starter
Transmission
Hey guys I got an easy one for you today. can anybody tell me how many quarts it take to fill up the trany in a 1995 ford power stroke with a 5 speed ?
Sparchuleta is offline
post #2 of 2 Old 06-03-2013, 06:58 PM
I hope this helps.
CAPACITIES:
Engine, with filter..........13.9 quarts [1]
Cooling System, Initial Fill..........22.7 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, C6-Shallow Pan Initial Fill..........5 quarts
Automatic Transmission, E4OD Initial Fill..........6.4 quarts
Automatic Transmission, C6-Deep Pan Initial Fill..........5.9 quarts
Automatic Transmission, Total Fill
4 speed E4OD..........Not Specified
3 speed C6-Deep..........13.5 quarts
3 speed C6-Shallow..........Not Specified
Manual Transmission, S5-42 (5-SPD)..........6.8 pints
Differential, Dana 44 Front..........3.6 pints [2]
Differential, Dana 50 Front..........3.8 pints [2]
Differential, Dana 60 Front..........5.9 pints [2]
Differential, Dana 60-IU Rear..........6.3 pints [2]
Differential, Dana 70-2U Rear..........6.6 pints [2]
Differential, Dana 70 HD Rear..........7.4 pints
Differential, Dana 80 Rear..........8.5 pints [2]
Differential, Ford 10.25 RingGear Rear..........7.4 pints [2]
Differential, With 8.8 or 9 RingGear Rear..........5.5 pints [2]
Transfer Case, BW1356E W/ PTO..........12.3 pints
Transfer Case, BW1345..........6.3 pints
Transfer Case, BW1356E/BW1356..........4 pints
[1] When refilling, remove dipstick to provide adequate venting
and allow oil to flow into crankcase.
[2] Fill to no more than 1/4 to 9/16 inch below fill plug hole.
TORQUES:
Oil Drain Plug.....NA ft/lbs
Manual Transmission
Fill Plug 25-30 ft/lbs
Drain Plug 25-30 ft/lbs
Transfer Case
Fill Plug 12 ft/lbs
Drain Plug 12 ft/lbs
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
