Rust - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-27-2013, 04:19 AM Thread Starter
jason7's Avatar
Rust
I'm new to this site, i joined because i just bought a late 99 f-250 7.3. When i was cleaning it i pulled the bed liner off and i saw that. Should i fix it or get a new bed?
ID:	117089   Click image for larger version
2005 F-350 lariat, Cold air intake, 4" mbrp exhaust, Long Block from Ashville engines, arp studs, bullet proof oil cooler, blue spring, egr delete, ect...
SOLD
Late 1999 F-250 7.3 Powerstroke with aem brute force intake, big head waist gate, aftermarket torque converter, shift kit, valve body, mag-hytec trans pan,edge evolution,ccv mod,foil delete, and bf goodrich mud 33's
jason7 is offline
post #2 of 4 Old 05-27-2013, 04:46 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
ouch that looks to me like a new bed is in the future...or a new bed liner.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 4 Old 05-27-2013, 05:00 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
get a new bed but if you wanna be cheap get a bed liner installed and have the spray in bed liner put onto the bed liner to harden it solid to the truck
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 4 Old 05-27-2013, 11:28 AM Thread Starter
jason7's Avatar
Thanks, i never thought of that. I bought it with one of the head lights cracked. Should i get an hid(like the other side) or put the 2005-7 style to match the grill?
SOLD
jason7 is offline
