03/06 bolt pattern
Anyone know if the 03 bolt pattern is the same as an 06 F350? I found a set of stock 18's, just not sure if they'll fit?
Darcy
yup, they will fit
Thanks Mark!!
Correct me if I'm wrong, but I was under the impression that the 05-06's had a different offset that would not work well with older models. Maybe its just that the new trucks have larger brakes and old rims wont fit them, not sure, but whatever it was I remember an issue with them somwhere.
Thanks Guy's
I'll check them this week and report the results so we all know, Darcy |
Ok, so heres the low down on the rims, 03-04 are interchangable and the 05-06 work, But they don't change over to each other, The 05-06 rims have a higher offset and they stick out of the wheel wells, The old rims will hit the brake calipers on the newer trucks, Thanks Darcy.
Up to 97 is 8 on 6 1/2, 99 to 03 are 8 on 178mm and the 05, 06 and the 07's are 8 on 200mm.
