friend not on forum blowing white smoke
he lost power, running eradically and blowing white smoke. any ideas? thank you
What does he own 6.0 or 7.3?
he has the 7.3
How many miles does he have? It could be lots of things but a few are low compression from worn rings or bent connecting rods, or coolant leaking into the cylinders from bad head gasket or injector sleeves.
around 200k with wastegate delete
Is he down on coolant? Does the exhaust have a antifreeze smell or sweet smell to it?
i called him, he is checking......
is the smoke only cold....or is it when the motor is warm too??
coolant ok, he has oil leaking out at turbo, would a bad turbo leak do this?
smoke when warm too
