Ordering some gauges WOW price!!! - Ford Powerstroke Diesel Forum
Old 02-27-2008, 11:42 PM
Send a message via AIM to 06Blackmamba Send a message via Yahoo to 06Blackmamba
So i got a Quad A Pillar. Plan on running 2 pyros one in manifold that i already drilled for chip then one after turbo. Then im trying to get fuel pressure were im going to hook up that idk yet lol. And oil temp. were thats going to hook up also in the block idk. Most oil temp goes in the pan but ill be dammed if im going to drill a hole in my oil pan hell with that. Any ideas were i can connect fuel pressure and oil temp to. Also is it really a good idea to run two pyros. or just one from manifold. thing i was worrying about was if one bank is running diff from otthere. OR!!!!! just get a cylinder head/water temp,or Volt meter.
this is going on a 06 i already have boost trans water but i like numbers better then just middle o SHIZZZZZZZZal red.
Any ideas would be greatly thankfull for
Old 02-27-2008, 11:48 PM
Also forgot Would it be easyier for elec or mechiancl gauges?
i kinda wanted mech cuz cheaper but what is easyier to hook up. guess elec?
Old 02-27-2008, 11:54 PM
Send a message via AIM to 4everlearning
Contact Raul@stealthautomotive on here he can set you up with a good set of guages for a great price. running two pyros is not needed but could be nice. If I was going to run both pyros I would put one in each manifold instead of how you mentioned. Also the stock gauges blow. get a tranny temp gauge and I would say to heck with the oil temp gauge. some others will chime in I am sure with some other ideas for you.
