Axle hop... Ladder bars? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-27-2008, 11:45 PM Thread Starter
Dallas4x4's Avatar
I wish i was able to floor it off the line or even changing gears fast. The axle just hopps like mad. Ive already gone broke 1 axle and new drive shaft/carrier bearing. Ive been thinking of getting some Ladder/Traction Bars. Are there any Good ones or inexpensive ones on the net?
1994.5, 2.5 lift, 35s on 17x10 MHTs, Intercooled, Stage 3 injectors, Nitrous, 6637, Water/Meth, 3" DP, 4" Magnaflow, IDM, TS Chip, 4.10s, 33s, 4 Pod pillar. 6000k HIDs.
Converted From ZF5 To E4OD w/ PCS TCM-2000 Tuneable Trans Computer, 6.0L Trans cooler and Triple Disc TC.
Up next Install electric fuel, ladder bars
Dallas4x4 is offline
post #2 of 6 Old 02-28-2008, 01:05 AM
rednekexprez's Avatar
REDNEKEXPREZ:
07 6.0 crew longbed 6spd
4" into 6"stacks cat/muffler delete
ranchhand bumpers front and rear
leveling kit,toolbox,gooseneckhitch
305/70/17 MTRs on Dick Cepek DC-1 black
suicide knob and trucknutz GONE
Fender flares,SCT tuned by Eric @ Innovative
110 gal aux. fuel tank.
FUTURE:
Over/under drive unit,cab lights
THE GRIM REAPER'S ARM JUST GOT LONGER: M107 Long-Range Sniper Rifle 2000 9900ix 260WB
usa:,
rednekexprez is offline
post #3 of 6 Old 02-28-2008, 01:08 AM
4everlearning's Avatar
Send a message via AIM to 4everlearning
The best one are going to be ones you build yourself but you can checkout any offroad supply and they should be able to hook you up with a decent set. also you could ask around in the vender jungle but you will have to be patient.
-Wes-
No truck anymore.
Originally Posted by dlonno View Post
Having the Looney and running the Eco is like having 2 girlfriends and choosing to bang the ugly one.
4everlearning is offline
post #4 of 6 Old 02-28-2008, 02:09 AM
duct tape & zip ties
bigcountrysg's Avatar
I would be checking out your driveline. If you do not have any lift right now and your already breaking things. You may want to check your driveline angle, as well as your differential. You may have something that needs repair.
Your not breaking an axle for no reason. You have something out of whack. Wether it is backlash on the pinion ring gear, or driveline angle, or a bad bearing in the diff.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 6 Old 02-28-2008, 04:09 AM
a truck
Matt P's Avatar
I had the same exact problem with my 95 f250. Whenever I floored it I got some nasty axle and it ended up shearing my drivers side centering pin on the rear axle and then the axle slipped back on the leaf pack. Not Good. Anyways I did exactly what you were thinking, I installed ladder bars from tuff country after consulting with a mechanic I have worked with on many occasions and he agreed this would be the best solution. Here are the ladder bars I bought the price isnt too bad,Ladder Bars by Tuff Country - 1980-96 Ford F150/F250/F350 (4WD Only)(1 Pair): Ultimate Auto Accessories hope this helps!
03 king ranch w/ a cummins
Matt P is offline
post #6 of 6 Old 02-28-2008, 03:22 PM
James4482's Avatar
i am about to put some ladder bars on my truck. as you can tell i am in much need. here is a set that i found that i liked. they are about $480 by time you buy the bars and the install kit. i liked the look of them.
L&L Products
Born: Feb 25 1999
10in lift
395 70 R16 MT Baha Claws
4:30 Gears
BTS Trans
ATS Compressor
7in turbo back stacks- Aussie
S&B intake
TS Chip
EGT, Boost, and Trans Temp
James4482 is offline
