primary battery?
in our trucks, which is the primary battery and which one to you hook up to in case you need a jump, or does it matter?
doesnt matter, ive jumped and been jumped from both no issue
yeah like stump said it doesn't matter. They are wired in parellel so what that does is double the cranking amps of the primary battery which is the drivers side if they both are charged and up to snuff so technically that would be the best one to jump from.
correct me if I am wrong but if it is in a parellel series shouldn't the started be a 24v than a 12v? if so why is our truck starters a 12volt???
u are thinking of wiring in series |
Not to sound like a smart a$$ but it doesn't matter which battery you use. Voltage is instantaneous in a circuit. (That 2 years of college I'm still paying for is useful sometimes)
So you are correct in a perfect theory but in the real world its always better to shorten the distance to make any resistance in the wires have a minimal effect on the jump....especially if the batteries are really weak... |
