New to Powerstrokes. EGR, Oil Cooler? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2013, 09:48 AM Thread Starter
jimmy21480's Avatar
So I just picked up my "new to me" 2007 F250. I am reading A LOT of bad things about these 6.0's. My truck has 138,000 miles and runs excellent.... as of now, i guess. My question is, Are ALL of these trucks prone to these failing EGR's, oil coolers and head gasket failure? If so, are there maintenance procedures to stop this from happening?
Thanks
jimmy21480 is offline
post #2 of 12 Old 05-02-2013, 09:52 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
EGR delet, OEM head gaskets, ARP head studs!
2000-7.3L is offline
post #3 of 12 Old 05-02-2013, 10:35 AM Thread Starter
jimmy21480's Avatar
That doesn't seem too bad at all. I've heard a lot about oil coolers clogging up too. Is that an issue on a lot of these trucks, or just a few here and there?
post #4 of 12 Old 05-02-2013, 10:35 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Before dropping all that coin on unnecessary repairs as of yet spend some money and get a good monitor for the tuck and watch the vitals. I recommend dashboss if you have an iOS device if not you can get something such as the Edge Insight CS/CTS or Scangauge II. If you want a good deal on the Edge insight pm me and I can get you hooked up.
As far as maintenance goes if I were you I would drain all of the fluids and put all new in along with new OEM filters. This way the truck will be on a all new maintenance schedule and have good new fluids in it. Also synthetic fluids will be more beneficial in your situation and help the truck last longer and run smoother. Any other questions feel free to ask.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 12 Old 05-02-2013, 10:56 AM Thread Starter
jimmy21480's Avatar
Tuscany thanks for the insight. Which vitals am i most concerned with? I've read that most people watch the EOT and ECT. what is a safe delta?
post #6 of 12 Old 05-02-2013, 11:21 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Anything over 15 degrees and you need a new oil cooler, BUT this has to be tested in the proper manner to get accurate numbers. You should also be monitoring FICM voltage as well as other vitals on the engine. These are things analog gauges can't monitor and this the reason for a monitor.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 12 Old 05-02-2013, 11:51 AM Thread Starter
jimmy21480's Avatar
Thanks Tuscany. My first task is to monitor my vitals and make sure everything is normal.
07 F250 6.0
Bone Stock
post #8 of 12 Old 05-02-2013, 04:08 PM
dieselman350's Avatar
get rid of the ford gold coolant and get a coolant filter
05 F-350 srw ccsb sport package
Atlas 40 tune
High idle mod
dieselman350 is offline
post #9 of 12 Old 05-02-2013, 05:02 PM Thread Starter
jimmy21480's Avatar
What is a good coolant to use?
07 F250 6.0
Bone Stock
post #10 of 12 Old 05-02-2013, 05:14 PM
Any CAT EC-1 rated extended life coolant Final Charge is one brand but there are many others
Atlas 40 tune
High idle mod
