New to board and 7.3L ownership. trans question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-30-2013, 10:23 AM Thread Starter
My transmission is starting to act up, and I'll probably need a rebuilt one, or just simply another one. Some mechanics say my problem is electrical and in the dash somewhere, some say its in the transmission. its been a major headache.
I have a 2000 f250 4x4 extended cab 6 3/4 bed 7.3L automatic. I normally use it as a daily drive and occasional tow for 7000lb load.
I haven't installed a transmission before, but i'll have time this summer and people to help.
I found a decent price on a rebuilt 4r100 out of town, but the guy hasn't gotten back to me yet with any details (transfer case, torque converter, ...) other than it ha a wiring harness.
I also found a local f250 that has a wrecked side and needs engine work, but he says the transmission is good. It is a 2001 f250 2wd extended cab long bed 5.4 triton v8 automatic. I understand its the same basic transmission, but i've got 4wd and the 7.3L.
My main question is this: Will these just mesh right in with my transfer case and stock driveshaft or will i have to invest serious cash in some other components?
Thanks to all that help me out.
millacd is offline
post #2 of 6 Old 04-30-2013, 10:27 AM
The gas transmission won't bolt up.
2000 F250 ccsb 4x4. 218,000 miles, 38r 1.0 housing with turbo master, 238/80% FFD hybrids, Stock tranny for now
, riff raff FRx, Autometer C2 series gauges, DIY tymar, remote start, Run on WMO, DP F6 with no start, modified stock, 60 tow codes,80 econo codes, 120 race codes, drive thru, and Waste oil 60 econo.
lariat 7.3 is offline
post #3 of 6 Old 04-30-2013, 10:35 AM Thread Starter
thanks. that's unfortunate. hopefully the guy out of town gets back to me with the details on his transmission today
millacd is offline
post #4 of 6 Old 05-01-2013, 07:12 PM Thread Starter
on another note, is it possible to put a zf6 transmission in my truck without too much difficulty?
millacd is offline
post #5 of 6 Old 05-09-2013, 07:15 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Welcome to the forum!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #6 of 6 Old 05-09-2013, 07:53 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's possible but work will be required, afaik the trans hump is much higher, need a clutch brake assembly, and PCM
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
