Boost Gauge - Ford Powerstroke Diesel Forum
Old 02-20-2008, 02:45 PM
Boost Gauge
Where abouts does it hook up at? I have hooked my Trans temp and EGT gauges up now I got do the boost and Im not quite sure where the T pipe hooks up at??
Old 02-20-2008, 03:05 PM
Can anyone help me
Old 02-20-2008, 03:25 PM
Not sure of what t-pipe your talking about. You can wire tap the map sensor or you can tap the intake elbow.
Old 02-20-2008, 03:31 PM
where is the map sensor located at?
Old 02-20-2008, 03:32 PM
you have the same year that i do. on the passenger side where the turbo boost tube goes into the block, that is where you can plug into for your boost gauge. there is a small tube there for the computer. you can hook into that.
