Prepper has question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-29-2013, 04:38 AM Thread Starter
Send a message via AIM to WVF350MAN
I am interested in what electronic parts are on my 97 7.3 powerstroke. I am a prepper and want to purchase replacement parts for my truck. It was a 96 F350 EFI gas truck. It was converted to diesel with a 97 7.3 powerstroke. What parts on this engine are electronic? Can they be replaced easily? Any discussion is welcomed. Was looking for a pre-electronic vehicle but couldn't find anything I liked. If North Korea were to shoot a nuke at us and explode it at a high altitude it would produce an EMP. This electronic pulse would disable electronics and is well know to be a real threat. I am not asking you to agree with the premise, I just need to know what would need to be replaced. Thanks in advance.
WVF350MAN is offline
post #2 of 13 Old 04-30-2013, 12:04 AM
JSchuricht's Avatar
The biggest thing would be the PCM and IDM. The 7.3 powerstroke is completely electronic, pre 94 1/2 trucks have a 7.3 that is mechanical. Another option would be swapping in a older 12v Cummins that's mechanical.
Anyways back to your question, PCM is the heart of the electric system, IDM fires the injectors. If you have a auto you will also want a gauge cluster, the transmission must have a good signal from the VSS on the rear axle that is sent to the cluster and converted to sign wave then fed to the PCM. I don't think the VSS would die but it's cheep so get a spare, also get a spare CPS. The CPS is known to fail even without a EMP blast. Beyond that you also have a RABS module for the rear antilock. I would expect it to fry but you can just pull the plug and continue driving without antilock brakes in the rear. I don't think sensors would fry but the throttle is electric so I would get a spare TPS just in case.
Almost forgot locations. The PCM is located behind the emergency break, it's easiest to get to from under the hood as it passes through the firewall. You will have to pull the fender liner down some to get clearence, I would say it's a 1/2 hr job to replace. IDM is really easy, it's located under the hood on the driver side fender and is easy to reach, 10 min job. Cluster is just a few small screws, 20 min. VSS is one bolt on the rear axle, 5 min. TPS is on the throttle peddal, 20 min. RABS is behind the glove box, 15 min. CPS is on the front of the block, not too hard to reach, 20 min.
JSchuricht is offline
post #3 of 13 Old 04-30-2013, 01:16 AM
HillbillyDeluxe39's Avatar
It won't matter, the spare replacement electrical parts you have will be fried as well as all the ones at the parts store. The initial E1 pulse from an EMP will destroy the sensors and pretty much anything with a circuit trace or fine wire in it.
Best bet is to get a mechanical injected truck with a manual transmission.
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #4 of 13 Old 04-30-2013, 01:25 AM
Quoted: 48 Post(s)
sell it and get a 12v Cummins with an air starter
drunk on diesel is offline
post #5 of 13 Old 04-30-2013, 03:00 AM
BIG Laing's Avatar
This is weird...
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #6 of 13 Old 04-30-2013, 04:31 AM
Quoted: 48 Post(s)
Lol @ NK being able to reach us with anything btw
post #7 of 13 Old 04-30-2013, 06:30 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Well if he keeps the spare parts in a led lined safe/bunker the spare electronics should be fine, what are you doing about extra diesel fuel?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 13 Old 04-30-2013, 10:41 AM
Lead would only block the gamma radiation, a Faraday cage would be more practical to protect from fluctuations in voltages. The nuke doesn't have to reach the US either, if detonated at the right altitude the EMP would spread beyond the blast.
2000 F250 CCSB 4x4
post #9 of 13 Old 05-01-2013, 12:13 AM
Blazin8556's Avatar
Originally Posted by BIG Laing View Post
This is weird...
I was thinking the same.
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
post #10 of 13 Old 05-01-2013, 02:39 AM
john galt's Avatar
Quoted: 1091 Post(s)
I would think a pre electronic gasser would be easiest to feed. just because gas is everywhere and diesel is a tad harder to come by. Unless you have a large private stash and or a way to create your own bio diesel.
I could be wrong about that depends on supplies in your area. you would do well to get a hand crank sump for pulling fuel also. again depends on your personal supplies etc.
interesting concept for sure I really cant help you with diesel knowledge as I am pretty new to the super duty experience. but so far as I know you will want an early 70's era vehicle with no computerized crap at all.
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
