Jimmy Jammer - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-19-2008, 09:46 PM Thread Starter
Jimmy Jammer
Anybody here install a Jimmy Jammer? Are they worth while? Do they really prevent theivery?
I'm getting more and more concerned about someone making off with my stroker. Apparently the drug cartels like to steal F-250 strokers because they can haul a heavy load (of drugs) and because of their off-road ability.
Am thinking of installing a Jimmy Jammer and a fuel pump cut-off switch somewhere under the dash. It may not be perfect but should slow the theives down a bit or stop them all together.
Look forward to hearing your comments.
Huston
huston is offline
post #2 of 7 Old 02-19-2008, 09:54 PM
jimmy jammers are pointless on superduties...its a well knowsn fact that the door handles are an easy break in point and most criminals dont even slim jim the doors...they just go through the door handles....
instead of a fuel pump cutoff....why not just put a switched relay to the main power to the PCM????
mschn99 is offline
post #3 of 7 Old 02-19-2008, 10:26 PM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
thats a great idea i wish i thought of that when i lived in CA!
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #4 of 7 Old 02-19-2008, 10:27 PM
the only downside to it is it will reset any check engine light if you turn the power off....since the PCM will lose power...
mschn99 is offline
post #5 of 7 Old 02-19-2008, 10:31 PM
95and05's Avatar
so whats the downside?
94 IDI
95and05 is offline
post #6 of 7 Old 02-19-2008, 10:31 PM
if you need to know what the code is
mschn99 is offline
post #7 of 7 Old 02-19-2008, 10:52 PM
95and05's Avatar
I have a code reader. the bad ones always come back anyway! cant get rid of them without fixing the problem. or takin it to you.
94 IDI
95and05 is offline
