a/c only blows on defrost - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-27-2013, 11:46 AM Thread Starter
I have a 2000 f250 and when I put the a/c to blow on the dash vents or any where else it wlill only blow on the defrost setting. I changed the ESOF hoses underneath the driver and passenger side wheel well but it still blows in the defrost setting. The pump is still working need help.
2000_7.3 is offline
post #2 of 6 Old 04-27-2013, 11:52 AM
Toms01PSD's Avatar
Quoted: 64 Post(s)
Checking the little valve under the passenger side of the dash. IIRC there will be a valve with a clear, white, and black hose on it. I think it also has a 90 degree on it. Make sure they are all secure.
Sent from AutoGuide.com App
Tom
2001 F250 7.3 auto 4x4 Lariat CCSB
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
ISSPRO Boost, Pyro, and Trans Gauges
Strictly Diesel Pre-Pump Filter/In-Tank Kit
Strictly Diesel Regulated Return and Fuel Bowl Delete
High Flow Banjo Bolts
Nitto AT's 305/70R16
2009 Pontiac G8 GT
Intake, Exhaust, Tune
Camaro 20's, Camaro SS Brembo's
2014 Chevy SS
Holden Badges, Intake, Exhaust, Coilovers, VMR 710's
Toms01PSD is offline
post #3 of 6 Old 04-27-2013, 12:21 PM Thread Starter
Do you know what the silver thing the white line connects to. The black line is working and the silver thing the white line isn't working everything else does though.
2000_7.3 is offline
post #4 of 6 Old 04-27-2013, 12:37 PM
Toms01PSD's Avatar
Quoted: 64 Post(s)
This is the thing I was referring to, sorry I got mixed up. The black wire in my ring finger has nothing to do with it. All I know is that I had the same issue and messing with this piece and the lines on it fixed it. I'm not sure where they go to be honest.
a/c only blows on defrost-imageuploadedbyautoguide1367094927.577670.jpg
Tom
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
2009 Pontiac G8 GT
2014 Chevy SS
post #5 of 6 Old 04-27-2013, 12:50 PM Thread Starter
We tested the black wire and it worked but the white wire that goes to the right connects to a silver deal and that's the problem just don't know what its called. Ps.thanks for app the help.
2000_7.3 is offline
post #6 of 6 Old 04-27-2013, 06:22 PM
Toms01PSD's Avatar
Quoted: 64 Post(s)
No problem. Try wiggling it to see if it made a difference?
Tom
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
2009 Pontiac G8 GT
2014 Chevy SS
Tags
a/c , defrost , leak , vaccume
