Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
Old 02-19-2008, 10:57 AM
monteman1978 monteman1978 is offline
Extension Cord is getting hot
Extension cord I run across my yard to plug my van in is getting hot at the point where it plugs into the wall. I am not sure if this is normal or could I have some kinda wiring issue in the van. I also have 1 other thing plugged into the socket and it doe not get hot nor does the outlet itself. Any help would be great.
Thank you in advanced.
Sean
Old 02-19-2008, 11:09 AM
silverF250 silverF250 is offline
I would think you need to go to a bigger gauge of wire.
Old 02-19-2008, 11:11 AM
pinkfloyd pinkfloyd is offline
Send a message via MSN to pinkfloyd
would definitly use a good extension cord 12/3
Old 02-19-2008, 11:12 AM
HorseMover HorseMover is offline
When I first plugged mine in the cord used to get hot. I went to a heavy cord (12) and now no problems.
Old 02-19-2008, 11:21 AM
Firemanbill Firemanbill is offline
Ditto... Get a heavier cord before you burn your house and, or, truck down.
Old 02-19-2008, 11:22 AM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
bigger cord.
Old 02-19-2008, 11:23 AM
Jubilee Jubilee is offline
Served Our Country
Ditto to what everybody said about a heavier cord. You can get a good quality heavy duty cord at an electrical supply store. Mine has an LED in the female plug so I can look outside and make sure that the heater is getting current as sometimes heavy rain/snow have tripped my GFI. Tucking the plug under your bumper will help to avoid this if parked outside.
Old 02-19-2008, 11:49 AM
bucwheat bucwheat is offline
That def sounds like the problem,go large.should solve the problem.
Old 02-19-2008, 12:53 PM
Cool I will get a new cord asap. This is the cord I use to run my lawn mower and stuff it is a good cord but I do not think it is 12 gauge.
Old 02-19-2008, 04:51 PM
sldghamr sldghamr is offline
yeah, i have a 12 gauge. i shoot clay pigeons with it.
