Manual vs. Electronic Gauges - Ford Powerstroke Diesel Forum
post #1 of 17 Old 09-17-2006, 09:41 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
Just an FYI for y'all running the digital gauge readouts like my Bully Dog Outlook Monitor. I was always concerned about my EGT's going up when I switched from my Predator to my Bully Dog Triple Dog. Krista (smokin'stroke) has noticed similar high EGT readings on her Bully Dog Monitor as well. SO she and I were discussing it and I decided to hook my manual gauge back up WITH my Outlook Monitor, to see if the temps were reading right. They're NOT. It's reads fine at low EGT's but if I get about 800 and higher the Outlook Monitor can vary at least 200 degrees!!! When my manual gauge read 900, my Outlook Monitor bounced over 1100 at one point. It makes me feel MUCH better about my +1600 EGT I BRIEFLY put on her the other day playing around. Anyway I just thought I'd share with you my findings running both gauges or the same sensor.
'05 F250, CC, FX4, 6.0 PSD
sct x4
MTW Stage 1 Turbo
DJ's FUEL+ - Fuel Pressure Intensifier
Nitrous Express NXd Stacker
Snow Performance Stage III Water/Meth Kit
ARP Studs
MBRP 4" Turbo Back w/ no Muffler & no Cat
DashBoss on my iPad
ISSPRO Gauges in Triple A-Pillar
High Idle Mod
Iron Horse Front Bumper Replacement
12,000LB MileMarker Winch
2000Watt Power Inverter
Viper 5901 Remote Start/Alarm
Pioneer Avic-D3 Stereo/Nav
Train Horns!
Valentine 1
Velvet ride shackles
RockStars on 33's
Big azz dent from a blown tire.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Please support our troops!
Rodslinger is offline
post #2 of 17 Old 09-19-2006, 04:47 AM
scooby53's Avatar
Send a message via AIM to scooby53
so which is better digital or dial?
scooby53 is offline
post #3 of 17 Old 09-19-2006, 05:00 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
I tend to want to believe my manual dial gauge. Is that because it's reading lower, maybe partly but also the way the digital fluctuates SO much it just seems to be off. I figure there is less to screw up in a manual gauge vs. a digital - plus ISSPRO is in the gauge business, Bully Dog isn't.
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #4 of 17 Old 09-19-2006, 05:06 AM
Brian's Avatar
thats a big difference in temps! does either company have any specs on the temp tolerance on their products?
brian
05 f350 crew, longbed, 4x4, 68k, lariat
Brian is offline
post #5 of 17 Old 09-19-2006, 05:19 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
Yeah that's why I was so freaked out about my EGT increase when I moved to the Bully Dog - turns out it WASN'T - the friggin gauge is high. I'm temped to get a 3rd manual gauge just to verify. Actually my Stage 3 water/meth kit that's coming in I think shows EGT's. THIS should be interesting.
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #6 of 17 Old 09-19-2006, 06:09 AM
The Fat Mod
Logan's Avatar
I have also noticed with my commander, that my PSI numbers are lower on my boost count. When I was running manual guages, I could get to 24-25. The Highest I have showed with the commander is 18-20. And the 20 was just for a split second.
Logan is offline
post #7 of 17 Old 09-19-2006, 06:25 AM Thread Starter
Gun Nut
Rodslinger's Avatar
Quoted: 122 Post(s)
My Outlook Monitor shows my highest at 43 or 46, something along those lines. Maybe I should by the head studs now.
sct x4
MTW Stage 1 Turbo
ARP Studs
DashBoss on my iPad
High Idle Mod
Train Horns!
Valentine 1
RockStars on 33's
post #8 of 17 Old 09-19-2006, 07:28 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I am pondering what I should do with my old analog gauge a-pillar setup. It's still in the truck and functional, minus the pyro. I unhooked the probe and plugged in the TST probe. The remote stays on and displays my temps and boost pressure when I actually turn the TST "off" and i've played around with the truck just on the programmer. Temps seem to be in the same range as they were when I was using the analog setup. Boost reads from the map sensor on the TST, vs the plastic pressure line from the intake to the gauge and they are right on par with each other. I was thinking about drilling another hole and mounting the old probe in it, but I may just hook both wires together to the single probe and not worry about it.
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #9 of 17 Old 09-19-2006, 07:32 PM
im fat and ugly
stump0331's Avatar
Is Is Nessacary To Have Multiple Pyro Taps Into The Manifold If You Have More Than One Egt Gauge??
2004 Excursion
stump0331 is offline
post #10 of 17 Old 09-19-2006, 07:54 PM
7.3 tech, supporter
fordnut85's Avatar
As far as i know you can run multiple pyros off one thermocouple. In fact alot of chips/tuners i have seen say that they will plug right into your existing thermocouple.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
