What is specific to trucks sold in the North? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-14-2008, 05:57 PM Thread Starter
I've been looking at trucks (350 Duallies 4X4) from Texas, Alabama and Florida and something just popped into my head....what type of heating equipment will these southern trucks be lacking, other than seats/mirrors of course? Do they all have block heaters and if not, can they be installed fairly easy? I wanted to buy a southern truck since they haven't been exposed to any harsh winters but I live in Chicago, so I need it to have the required heating "accessories". All of this info is available in the VIN I'm guessing. Thanks for any help guys
yellowhorse7 is offline
post #2 of 13 Old 02-14-2008, 06:02 PM
BamaSixGun's Avatar
Those features are going to be standard equipment on most if not all of the high models (lariat, King Ranch, etc.) unless they were ordered delete for some reason.
I could be wrong, but thats my take.
My 2004 has the heater block & plug, heated mirrors and seats as well.
I also live in Alabama
Stephen
BamaSixGun is offline
post #3 of 13 Old 02-15-2008, 04:12 PM
AvroAero's Avatar
I think they're fairly similar. My uncle just baught a 250 from florida and brought it back to Ontario. The only heat feature it didnt have was heated mirrors but it was a XLT only so it was likely the model that did it. I'm also buying an excursion from the south and bringing it back. I'd think any diesel would have a block heater. Only smaller 4 bangers and a few sixes I'd question. And I don't think a block heater install is that easy, may be wrong.
One note, when you bring your truck north make sure you've had the/a dealer drain the collant and put 100% anti freeze in, and run through all the winshield washer fluid and put pure stuff in. We thought of the antifreeze part but forgot about the windshield washer fluid and once you lose it in a snow storm life sucks. Especially trying to thaw the line and run the tank dry to put pure stuff in.
2004 Ford Excursion 6.0
-SCT livewire w/ innovative extreme tunes
-Banks monster exhaust
-Zoodad
-05 conversion w/ harley headlamps & HIDs
-Viper 5900 remotestart/alarm
-ARP studs
-EGR delete
-Defender roof rack with 600W of light
-whelen hideaway strobes
-Sound off Predator dual red-red
-Whelen 500 4 amber 2 blue
AvroAero is offline
post #4 of 13 Old 02-15-2008, 04:18 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
heater
All 7.3's should have the heater and cord, all 6.0s up to '05 I believe should have the heater and cord and the '06 and up if they were delivered to the southern states will have the heater but no cord. You will have to supply the cord.
post #5 of 13 Old 02-15-2008, 04:38 PM
WD40's Avatar
Quoted: 27 Post(s)
I have only seen one truck that didn't have a block heater that we could fine and it was a truck shipped to AZ. when new. Like everyone has all ready said, just check these things out before you buy. It gets cold down here also, that's why I go to South Texas to get away from the cold. LOL 85 today
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #6 of 13 Old 02-15-2008, 06:42 PM
My 2003 came from texas with seat heaters, heated mirrors, and the block heater and cord - my 2005 was bought straight off the hauler in MI and didn't even have the block heater cord.
Things I would be more concerned with - check/replace the coolant before it freezes, it isn't always good to real low temperatures where it doesn't get cold - same goes for the wiper fluid. also they sometimes use heavier weight oils in warmer states than in colder. Also, if you buy during the winter, they sometime blend the fuel different up here in teh winter to help engines run better, and if you have it shipped it may have non-winter blend fuel in it when it arrives, and will run poorly.
We flew down and picked ours up, checked the coolant and oil before we left, fueled up a few times on the way up, and figured out about the washer solvent the hard way
and i maintain that while it isn't 80F year round, it still does not get cold, even in northern texas - despite the fact it was snowing when we arrived to pick ours up
Safir is offline
post #7 of 13 Old 02-15-2008, 07:08 PM
7.3's are available with or without a cold weather package for most superduty years......the cold weather package is the EBPV and block heater cord and fuel heater......
Heated mirrors were always an option and may or may not be on any truck...
6.0's only have the option of the block heater for a cold weather option (also the fuel heater was removed on some later 6.0's.....as no longer being an option)
mschn99 is offline
post #8 of 13 Old 02-16-2008, 07:00 AM Thread Starter
Not sure I understand this statement.
post #9 of 13 Old 02-16-2008, 07:30 AM
my bad....i meant to say block heater cord....they all have block heaters....
the fuel heater was deleted on some later 6.0's becasue they found it wanst needed.....
mschn99 is offline
post #10 of 13 Old 02-16-2008, 07:32 AM
mountainlander's Avatar
Same with my 04, and it's a Texas truck from birth until now.
Robert Fenton
'Bessie' --2004 Excursion Limited 4x4 6.0L --SOLD with a blown head gasket, Bad EGR Valve and Cooler, Bad oil cooler
And then there was one:
4" Turbo Back from Gus @
--in garage waiting to be installed
Support our boys through
mountainlander is offline
