Carbon Build Up??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-13-2008, 08:03 AM Thread Starter
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
Question Carbon Build Up???
Before I go and tear some guys a new one on another forum for call BS on me, talk to me about carbon build up guys? What causes it? Wouldn't I have to worry more about it if I had the DPF on there since the DPF is acting like a cork and catching all the soot?
-Julian
4th 6.fo
TwinTurboStroker is offline
post #2 of 4 Old 02-13-2008, 09:10 AM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
Carbon Build-Up
Check out that link Julian
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 4 Old 02-13-2008, 09:14 AM Thread Starter
Let's Run'em
Quoted: 10 Post(s)
Thanks John.....so you tell you me bud, based on what that said about oil and motors being over fueled, wouldn't you think carbon would be more of a problem with trucks that still have the DPF and regen mode because of the extra fuel that is being used?
-Julian
4th 6.fo
post #4 of 4 Old 02-13-2008, 09:22 AM
Quoted: 5 Post(s)
I would think so but if the motor runs at a hot temp from higher speeds or towing it really shouldnt matter. the hotter temps will "burn" off the carbon regardless if you have a dpf or not. If you baby it or drive like a grandma putting around everywhere it will build up carbon with or without a dpf.
John Wayne
REDNECK VALDEZ
You can find me on
