where to place space heater? - Ford Powerstroke Diesel Forum
Old 02-12-2008, 02:31 PM
Question where to place space heater?
I live in MN and am having cold weather starting problms....surprise surprise.
I put a small space heater under the oil pan but wonder if there is any better place I would want the heat to go. I do have the truck pluged in.
as long as I am here, my truck starts in cold weather but quits after @ 10 seconds because it is not refilling the oil resevoir-could this be a oil pump problem?
97-f-250 4x4 ext cab
thnx
Malcolm
Old 02-12-2008, 03:27 PM
I would think the placement of the heater is fine since hot air rises. Don't know about your oil pump problem though, here's a bump for ya.
Old 02-12-2008, 03:33 PM
try using a lighter wieght oil, maybe a synthetic alot of the superduty diesel guys use the rotela synthetic with good cold starting
