Front end shake even w/ new tires. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-12-2008, 08:02 AM Thread Starter
metronil's Avatar
Hey guys my 2005 F250 super duty, Stampede has had 2 sets of tires on it since i bought it back in 2005. At around 40 -50 mph the front end gets real bouncy and bumpy, you notice it a lot more with the xterra tires that came w/ it new. I took it to ford they said tires out of balance, etc.
Got them balanced but same problems...it got so bad that i couldnt even let my wife drive it, between 35-45 mph if you hit a pothole the whole steering wheel would shake violently until you slowed down real fast, same thing between 40-50, but not as vigorous a shake. after 50 it was fine.
So thinking it was those big meaty tires i went and bought new ones, same size but not mud tires, just good BF goodrich truck tires.315/70R-17
Things are okay but i still feel the steering wheel shake, just a little, between 40 and 50. Im wondering how long it will take for these tires to get to the point that we had the uncontrollable wheel shake, or is it just the front end alignment that could do that?
Also wondering if this is common in big trucks with big tires like this one.
metronil is offline
post #2 of 9 Old 02-12-2008, 08:17 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
Sounds like something in the front end to me, possibly something loose?
Bumping this up for ya, someone should be along soon with a better idea.
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #3 of 9 Old 02-12-2008, 08:45 PM
Cj Ford's Avatar
trac bar bushings .. the axle is likely walking side to side often referred to as death wobble.. usually more common on dodges but I have had it happen on fords too
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #4 of 9 Old 02-12-2008, 08:51 PM
My sisters 06 did this. She took it in 2 times and they tried the basics. Then she took it in a 3rd time and they said it was the way it was and she told the service manager to drive it and he did and the truck death wobbled and he almost crashed it. Turns out the balljoints were bad and caster cams were junk. Those got replaced and the truck is fine. It aslo has 37's.
2005F250 is offline
post #5 of 9 Old 02-12-2008, 08:51 PM
mountainlander's Avatar
Happens on lifted Jeeps too.
Track bar bolts could be loose, could be too little or too much toe-in, could be control arm bushings....
Good luck!
Robert Fenton
'Bessie' --2004 Excursion Limited 4x4 6.0L --SOLD with a blown head gasket, Bad EGR Valve and Cooler, Bad oil cooler
And then there was one:
4" Turbo Back from Gus @
--in garage waiting to be installed
Support our boys through
mountainlander is offline
post #6 of 9 Old 02-12-2008, 09:06 PM
tonyf250's Avatar
I am fighting this right now. I have it at 4 wheel parts for an inspection. After talking to Fabtech and the tech at 4 wheel parts we are replacing the track bar tommorrow and the alighnment will be done. It is 350 lb/ft on the pitman arm nut 400 lb/ft on the track bar bolt, 18" tow in and 3.5-5* positive caster.(Fabtech Specs!!) I will let you knopw how this turns out. I am at my wits end!!
'05 F-250 CC 4x4 6.0
6" Fabtech lift
BANKS exhaust
Airaid intake
SCT tuner
w/Matt's tunes!
Auto Meter Pro-Comp Ultra-Lite boost,pyro,tranny
A-pillar gauge mount
Zoodad
mod
35"x12.50"x20" Mikey Thompson Baja ATZ's
20"x10" MotoMetals
tonyf250 is offline
post #7 of 9 Old 03-08-2008, 09:10 AM Thread Starter
metronil's Avatar
Thank you guys, i will take it in and have them check it again and this knowledge will hopefully help them zero in on it rather than send me packing.
i dont like the sound of 'death wobble' at all.
metronil is offline
post #8 of 9 Old 03-08-2008, 09:12 AM
tonyf250's Avatar
THey fixed mine with a new trac bar and a good alignment.
6" Fabtech lift
BANKS exhaust
Airaid intake
SCT tuner
w/Matt's tunes!
Zoodad
mod
20"x10" MotoMetals
tonyf250 is offline
post #9 of 9 Old 03-08-2008, 09:21 AM
screech's Avatar
I think you are all right. My friends jeep also did this,adj. contol lins fixed it on that(canged caster) I also rec. the track bar for yours. Energy suspension made poly. bushings for mine.
96 350 Reg.cab 7.3 5sp. 4x4
3.5 to 4in dp, 4in strait pipe
4in Superlift w/ Airlift airbags on 315/75/16 Procomp X-Allterain W16x10Procomp wheels
Ba### Technicooler(the bad word)
Boost & E.G.T. Guages
Superchips programer(for now)
fpr mod
d.i.y. intake
South Bend clutch
79 150 4x4 (my wheelin truck)
420ci M motor,c6
4in lift, 35x12.5x15 Mud Terains
was old driver too much $$$--6-9mpg of premium(11.5to1)
screech is offline
