Transfer case ? - Ford Powerstroke Diesel Forum
Old 02-10-2008, 07:46 PM
Transfer case ?
I just changed out my tranny and put it all back in and now the transfer case won't let me shift out of 4x4 Low or Nuetral. Any thoughts. I will pull the case down tomorrow and see if it will shift off the tranny and reinstall in the
2H position.
thanks,
Steve
Old 02-10-2008, 07:53 PM
Desert Shield/Storm Vet
Give us some more info bud! What truck year helps alot?
Old 02-10-2008, 07:57 PM
are you meeting all the perameters??
truck needs to be in nuetral......completely stopped....with the foot on the brake pedal....
Also....are your brake light working.....if they arent then it wont shift out of four low either...
Old 02-10-2008, 07:58 PM
Also is it a manual on the floor or electric shift transfer case?
Old 02-10-2008, 08:01 PM
Brake lights work, Manual on the floor shifting. Also its a 96 f250 PSD, I will try the in neutral and try to shift out of 4low. thanks for replying so quickly and any other thoughts are appreciated.
thanks,
Steve
Old 02-10-2008, 08:09 PM
Does the linkage move at all? In other words does the shifter move in the cab?
Old 02-11-2008, 10:04 AM
Yes I can shift in and out of 4low and nuetral.
Old 02-11-2008, 11:40 AM
Thanks for all the help. Simple fix. Just put tranny into nuetral and presto. Thanks again I didn't know that the tranny needed to be in to nuetral to go down to the lower gears atleast I didn't remember that. Been awhile since I had to venture down into those gears.
thanks again,
Steve
