Injector failure??? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-10-2008, 07:07 PM Thread Starter
wustydemo's Avatar
Injector failure???
How can you tell if an injector is failing? Is there a particular noise to listen for?
wustydemo is offline
post #2 of 9 Old 02-10-2008, 07:32 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Are you having any issues? Have you checked all the easy things first?You can do an injector buzz test to check the electrical side and then you can do a cylinder contribution test. I don't think the contribution test will always tell you if you have a bad injector though. One of the techs will chime in Im sure
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 9 Old 02-10-2008, 07:51 PM
sometimes they "knock" a little...but why are you asking??
mschn99 is offline
post #4 of 9 Old 02-11-2008, 02:24 PM Thread Starter
wustydemo's Avatar
I am noticing a noise when the motor is running. It makes the noise a gas motor will make when the valves rattle. You can hear it at idle and when running down the road...really noticeable when giving the truck gas. It also makes a knocking noise when warming up. Getting concerned because I thought it was nothing but it is not going away.
post #5 of 9 Old 02-11-2008, 02:25 PM Thread Starter
wustydemo's Avatar
What is a injector buzz test and a cylinder contribution test and how do you do them?
post #6 of 9 Old 02-11-2008, 02:37 PM
PSDfan99's Avatar
You can do these two tests with a good scan tool, one that an automitive repair garage or dealership would have. Bascially what they do is... a buzz test tests whether the injector wiring and solinoid is working, and a contribution test tests how each cylinder is running. If an injector was 'bad' and not firing, chances are that it would fail a contribution test. If you had an injector unplugged or a bad wiring harnedd it would probably fail a buzz test and set the check engine light.
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #7 of 9 Old 02-11-2008, 02:47 PM
vitalidle's Avatar
You need someone who has a scanner to perform those tests. A dealer or a mechanic who can run it on a powerstroke. The buzz test checks the electrical side of the injector. The contribution test will check the rotational velocity of the piston to let you know if you have a bad cylinder or not.
Auto 93,000 miles
DP Tuner F5
post #8 of 9 Old 02-11-2008, 02:48 PM
vitalidle's Avatar
Oh crap already answered I was half way through typing and the phone rang
Auto 93,000 miles
DP Tuner F5
post #9 of 9 Old 02-11-2008, 03:31 PM Thread Starter
wustydemo's Avatar
What does the sounds I am describing sound like? An injector?
