EGT Monitoring - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-30-2008, 11:16 PM Thread Starter
EGT Monitoring
Hey Guys,
I am curious on opinions about GET monitoring.
Is it important if you run stock, no mods?
Is it worth the cost to install?
I am interested in hearing opinions on GET gages.
Appreciate your feedback as I am considering adding the gage. Just not sure I really need it.
My Truck & Trailer weight is around K + or -. I don't drive aggressively and very rarely take her over 70. Never go faster than the posted when hauling and even slower on grades.
Thanks and if this has been discussed before I did not find anything searching for GET. A link or recommended search term would help.
Reagrds,
AdamG
Ford Custom F-550 Hauler
AdamG is offline
post #2 of 4 Old 01-30-2008, 11:24 PM
im fat and ugly
stump0331's Avatar
you really dont have a need for an EGT if you are bone stock, the stock fuel delivery wont allow you to exceed same temps
2004 Excursion
stump0331 is offline
post #3 of 4 Old 01-30-2008, 11:26 PM
PRCA Bullfighter's Avatar
Personal opion, I think it's a good idea to monitor your EGT's. You'd probably be suprprised as to how hot you may be running even stock. If nothing else it's good piece of mind.
Gauges were the first mods on both my trucks. FYI the Ford typically runs higher EGT's than my Dodge and the Ford engine is stock.
PRCA Bullfighter is offline
post #4 of 4 Old 01-30-2008, 11:45 PM
DoubleDpsd's Avatar
If I was towing what is behind the rig in your avator, I would run an egt gauge.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
