New Owner - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-27-2013, 07:00 PM Thread Starter
New Owner
Just purchased a 2006 F350 supercab with 153,000 miles. Where should I start for preventive maintenance. Truck runs good. Thanks...
dinos is offline
post #2 of 6 Old 03-28-2013, 06:27 AM
kystanger's Avatar
Any time I buy a used vehicle I always start with changing all fluids and filters. I would change engine oil and filter useing a good diesel oil of you chose and a motorcraft oil filter, Then change front and rear diff gear oil, and then transmission and transfer case oil. Then a new air filter and change both fuel filters. That way you know the conditon of all fluids and filters. After that I would just start running a fuel additive of your chose.
2008 f350 4x4 Stock
(SOLD)2001 f250 4x4
319,000 miles and counting.
6637 intake, 4 inch MBRP exhaust,gauges,203 degree therostat, leveling kit, transgo tugger kit, front and rear mag-hytec diff covers, more to come.
kystanger is offline
post #3 of 6 Old 03-28-2013, 11:00 AM Thread Starter
Thank you.
dinos is offline
post #4 of 6 Old 03-28-2013, 11:05 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
100% agree with that. But Id also throw a monitor on that beast ASAP.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 6 Old 03-28-2013, 08:03 PM Thread Starter
what do you mean by a monitor. Thanks!!!
dinos is offline
post #6 of 6 Old 03-28-2013, 08:26 PM
Wannabitawerm's Avatar
Read the stickies in the 6.0 forum. You need to monitor the vital; things the gauges wont tell you. Also, the 6.0 needs to be ran hard and cooled down after, (let it idle for a bit).
Read them ASAP and get the oasis report on the truck. Very important.
Sent from AutoGuide.com App
Wannabitawerm is offline
