Ford vs Chevy bed bend video, thoughts? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-24-2013, 09:02 AM Thread Starter
Hey all! Just want to say up front that I am a die-hard Ford fanatic. I'm surprised i'm only just now seeing this video and wanted some of your thoughts on it. Is the test rigged?
Ruben
2008 F250 4x4 6.4PSD Auto
Tuned, deleted, studded, piped, bts'd...
Rubenk is offline
post #2 of 17 Old 03-24-2013, 09:12 AM
I will leave this one to others, but I would not buy into all that. Just because the frame does not flex on the Chevy does not mean its better, especially in off road situations. Something else will eventually give on the chevy since there is virtually no flex.
Everyone has their own opinions and needs.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 17 Old 03-24-2013, 09:15 AM
jmhelems's Avatar
Interesting for sure...I can't speak for others but I've had 4000 lbs. of dirt (yes wayyy over capacity I know) in my bed and granted I didn't do any severe offroading but the bed held up fine with no lasting damage done to it. My only guess is that this is due to the age of the super duty platform? I mean the beds haven't changed since 1999 realistically, and the frame has had it's tweaks but no major overhauls that I know of so maybe this explains it? Of course if I remember right there's a frame twist test Ford put out with just the frames themselves that showed the super duty held up better but who knows. Either way I'd still take my Ford over the light duty "HD's" GM offers as I know that in most other areas I feel more comfortable with the abilities my truck has.
2008 F-250 Badlander...2.5" level, 5" blocks, 35's on 22's, H&S Mini-Maxx, 5" Flo-Pro straight pipe, S&B, KEM
jmhelems is offline
post #4 of 17 Old 03-24-2013, 09:35 AM
6.0f250firstcar's Avatar
One answer. Look who's sponsoring the test. That's why any test other than car and driver or Pickuptrucks.com is bs. If Ford's sponsoring a test, Ford will win. Same with Ram and Chebby. Doesn't mean a thing.
Ryan
6.0f250firstcar is offline
post #5 of 17 Old 03-24-2013, 09:40 AM
Njstroker91's Avatar
I personally like the trailer sway test with the big three that's a good one.
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #6 of 17 Old 03-24-2013, 11:25 AM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Ever watch a semi-truck twist when the driver lets the clutch out too quick from a stop light? They tow more than any 1 ton pickup will ever see.
The springs need to be heavy to resist squatting under load. That same spring won't offer a lot of articulation when the truck is empty. So frames are designed to flex "a little". However, these are COMPLETELY different forces than what you would find applied to the frame when towing/hauling (just like the previously mentioned semis).
Another factor that comes into play with articulation is the suspension design. In off-road situations the terrain constantly varies an independent front suspension will suit you better as each wheel works independent and does not affect the other. You clearly see it working on the front ramp. HOWEVER, if you bought a 1 ton diesel truck... your goal is to use said truck for a work horse. A solid front axle will remain stable and reliable when doing tasks in 4wd such as plowing snow. Its all about priorities. If you want a truck to move mountains on and off pavement, the Ford is a good bet. If you want a truck to soak up the lumps and bumps on and off road and articulate over obstacles, get a toyota tacoma.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #7 of 17 Old 03-24-2013, 08:21 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
no flex = broken parts
this is similar to rubber motor mounts right? no movement cause stuff to break, so some movement/flex is not so bad>?
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 17 Old 03-24-2013, 08:45 PM
Rodslinger's B1TCH
gm frames bend too
everyone has seen this one
i have a picture somewhere of a guy with a gmc with a flatdeck trailer where an excavator places a big tree on the trailer. the tounge weight is too much for the truck and the frame bends into a roof shape between the cab and box.
so gm built a frame that won't bend and had to make up for the lack of flexibility with a complicated suspension that is packed with crappy bushings all over the place. drive the gm and ford down a lumpy highway at 100,000miles with all of the original parts and see what does better.
steve604 is offline
post #9 of 17 Old 03-24-2013, 09:08 PM
Joel's Avatar
Quoted: 10 Post(s)
Steve! Stop wasting time posting videos and install that new wheel. Then tell me if Its awesome and i need to go buy one.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 17 Old 03-24-2013, 09:13 PM
Rodslinger's B1TCH
Maybe next saturday? On call for work was busy for me this weekend. If you're in Abby you can come by and help if you want....
steve604 is offline
