Horn wiring - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-23-2013, 04:22 PM Thread Starter
Leatherneck1428's Avatar
Horn wiring
I an installing a horn blaster train horn in my 02 F250. I need help locating the factory horn wire under my steering column. Can anyone help? Also if any of you have installed a train horn, where did you tie your power for the pump into and how did you install the in line fuse they provided?
Leatherneck1428 is offline
post #2 of 6 Old 03-25-2013, 06:20 AM Thread Starter
Thought this site was designed to help someone out? I guess I was wrong.
post #3 of 6 Old 03-25-2013, 07:01 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
But,,, you know you chose "General Diesel Discussions" to ask a question that, while it might be General to you, really would be quickly answered if you had put it in the proper, specific, forum (7.3 General) below.
Don't blame the membership if you put this in an obscure "General" place (that, if appropriate, would contain Thousands of post everyday....)
When I did my Train Horns, I used the wire that actually went to the electric horn (the wheel sw applies Ground, the horn relay gets "tripped" by the application of that ground) so, you would need to wire your new horns relay to react to either Ground from the wheel OR the 12v the stock horn sees (post relay) as I did. It was the 12v wire, and it is Yellow with a Green tracer.
NoRalPh is offline
post #4 of 6 Old 03-25-2013, 08:45 AM Thread Starter
My apologizes, thought I had posted in the right spot. Thank you for the much needed advice. In the future I will pay more attention to the area I post in. I hope to have the horns hooked up today. The only thing left is pwr to the compressor and hooking up the horn. Again, thank you for your reply.
post #5 of 6 Old 03-25-2013, 09:51 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
heres the setup i used and it works really well for my application
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 6 Old 03-25-2013, 02:36 PM Thread Starter
Thanks for the advice. Got the horns hooked up and they sound amazing.
